I am using
ROS2 Foxy
Nav2 for navigation
Slam-toolbox for mapping and localization
create_robot for odom
When I send a command to the ActionService navigate_to_pose
from Nav2, most of the time bt_navigator
will fail with the error:
[bt_navigator-9] [ERROR] [1627933160.614862066] [bt_navigator]: Action server failed while executing action callback: "send_goal failed"
[bt_navigator-9] [WARN] [1627933160.615170308] [bt_navigator]: [navigate_to_pose] [ActionServer] Aborting handle.
As far as I can tell, I am calling the Service correctly and my issue might be with my configuration. My config for nav2 can be found here: https://pastebin.com/KkRUAB5s
I have also thrown all logs from this specific run into a pastebin here: https://pastebin.com/Rx1ZMUeg the error in question can be found on lines 428 & 429
Originally posted by jacobwaller on ROS Answers with karma: 33 on 2021-08-02
