Hello !
I try to run the move_base node on a real robot. When I run it in simulation (with another robot), it works successfully.
But, when I try to bring up the navigation stack on a real robot, the move_base action server doesn't come up.
Indeed, when I launch the move_base node, I get continuously the unexpected following warning:
[ WARN] [1466504490.216963462]: Costmap2DROS transform timeout. Current time: 1466504490.2169, global_pose stamp: 1466504032.8989, tolerance: 0.3000
Moreover, when I run my own C++ node in order to send a goal command, the program stays blocked inside the waitForServer loop, this loop is as follows:
while(!ac.waitForServer(ros::Duration(5.0)))
    ROS_INFO("Waiting for the move_base action server to come up");
I don't understand why it doesn't work and why when I run the move_base node the move_base action server doesn't come up.
If anyone can help me, I would be very grateful,
lfr
update 1
Here the result of the roswtf command:
WARNING: Package "ompl" does not follow the version conventions. It should not contain leading zeros (unless the number is 0).
Loaded plugin tf.tfwtf
No package or stack in context
Static checks summary:
No errors or warnings
Beginning tests of your ROS graph. These may take awhile...
analyzing graph...
... done analyzing graph
running graph rules...
... done running graph rules
running tf checks, this will take a second...
... tf checks complete
Online checks summary:
Found 3 warning(s).
Warnings are things that may be just fine, but are sometimes at fault
WARNING The following node subscriptions are unconnected:
 * /teleop:
   * /torso_controller/state
WARNING The following nodes are unexpectedly connected:
 * /mugiro_node->/rqt_gui_py_node_4590 (/tf)
WARNING Received out-of-date/future transforms:
 * receiving transform from [/sickS3000_publisher] that differed from ROS time by -460.430734051s
 * receiving transform from [/Publish_odom_TF] that differed from ROS time by -460.43225327s
You can find the tf tree below:
image description
And the graph here:
image description
Originally posted by lfr on ROS Answers with karma: 201 on 2016-06-21
Comment by Orhan on 2016-06-21:
Look to your tf (rosrun rqt_tf_tree rqt_tf_tree ) and node graph (rosrun rqt_graph rqt_graph). Which topics/nodes are unconnected? What's the differences between simulation's graph and real robot's graph? Also you can use roswtf command for looking whats going on.
Comment by lfr on 2016-06-22:
I updated the question, thanks for your help
Comment by Orhan on 2016-06-22:
I think there is a problem with your pose estimation node, In a simulation, gazebo publishes odometry and transformation between odom and base_link. I think your problem is in your Publissh_odom_TF node (or mugiro_node).
Comment by lfr on 2016-06-23:
Ok, could you tell me what kind of problem may appear with these nodes because I still don't understand why it doesn't work.
Comment by Orhan on 2016-06-23:
It may be message type (stamped or not stamped) or publishing with wrong frame. Your screenshots are from real robot. Compare them with simulation's graph and tf tree. I think you should publish odom transformation from /mugiro_node directly. Why you using /Publish_odom_TF?
Ah ok, thanks. But didn't write these nodes, I got the robot and these nodes from other ones. My task is to bring up the navigation stack in order to do some tests with the planner (that I have chosen). I will see about tf, I think this is the problem too. Thank you for your help.
You're welcome.
The problem was the clocks of my computer and the robot was not synchronized. The difference was about 500 sec (this is why even setting the transform_tolerance value to 10 sec -> the max value, it didn't change anything). After synchronizing it, it worked properly.
Thanks to Orhangazi44 for helping me,
lfr
Originally posted by lfr with karma: 201 on 2016-06-28
Comment by RRK on 2022-02-01:
Can you elaborate more, how to solve this issue?
