I want the make the coordinates be the same as real robot ,but I cannot find where can I achieve this. I guess by changing some factors in urdf file will be useful. Could you tell where can I change the positive direction of coordinates. Here is part of the urdf file. Please take base link's coordinate as an example.Thx!
<link
    name="base_link">
    <inertial>
      <origin
        xyz="2.33471583537977E-06 0.00662907239788253 1.33004670421342"
        rpy="0 0 0" />
      <mass
        value="25.8577669048994" />
      <inertia
        ixx="0.267014137924139"
        ixy="-1.36584455424997E-05"
        ixz="4.24690442718128E-07"
        iyy="0.472244407235779"
        iyz="5.34065558451065E-05"
        izz="0.549554614712028" />
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
          filename="package://dscr5_6/meshes/base_link.STL" />
      </geometry>
      <material
        name="">
        <color
          rgba="0.298039215686275 0.298039215686275 0.298039215686275 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
      </geometry>
    </collision>
  </link>
  <link
    name="rlink1">
    <inertial>
      <origin
        xyz="-3.48537472660837E-07 -0.0233818482234878 -0.0427896937411072"
        rpy="0 0 0" />
      <mass
        value="4.9503936266377" />
      <inertia
        ixx="0.0280328872192691"
        ixy="-1.09421874885135E-08"
        ixz="8.01870940105599E-08"
        iyy="0.0290016533494644"
        iyz="0.00182600668247838"
        izz="0.0175058159650953" />
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 3.14" />
      <geometry>
        <mesh
          filename="package://dscr5_6/meshes/rlink1.STL" />
      </geometry>
      <material
        name="">
        <color
          rgba="1 1 1 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
      </geometry>
    </collision>
  </link>
  <joint
    name="rjoint1"
    type="revolute">
    <origin
      xyz="-0.384999999999999 0 1.33"
      rpy="3.14 1.57 0" />
    <parent
      link="base_link" />
    <child
      link="rlink1" />
    <axis
      xyz="0 0 1" />
    <limit
      lower="-3.14"
      upper="3.14"
      effort="60"
      velocity="2.088" />
  </joint>
Originally posted by xiaozhenghong on ROS Answers with karma: 5 on 2021-04-11
It depends how you want to change the axes. You can rotate them as a whole, but you can't change them relative to each other. For example, you can't reverse the direction of the x-axis without also reversing y or z, which would constitute a 180° rotation. This is because, as stated in REP 103, all coordinate systems are right-handed, and reversing only one axis would make it left-handed.
If you want to rotate the whole frame, use the rpy attribute in the elements you want to rotate. Have you looked through the URDF tutorials? The Building a Visual Robot Model with URDF from Scratch tutorial involves rotating links.
If I missed the point of your question, please clarify what you would like to know.
Originally posted by tryan with karma: 1421 on 2021-04-11
