I have been using ros serial for a weeks to communicate with my Arduino. However, today when I ran the command
rosrun rosserial_arduino serial_node.py /dev/ttyACM0
I got this error
File "/home/ryley/catkin_ws/devel/lib/rosserial_arduino/serial_node.py", line 15, in <module>
exec(compile(fh.read(), python_script, 'exec'), context)
File "/home/ryley/catkin_ws/src/rosserial/rosserial_arduino/nodes/serial_node.py", line 37, in <module>
from rosserial_arduino import SerialClient
File "/home/ryley/catkin_ws/devel/lib/python3/dist-packages/rosserial_arduino/__init__.py", line 34, in <module>
exec(__fh.read())
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'SerialClient'
I have source my workspace in both the roscore terminal and where I run the command. I just don't understand what could have affected rosserial since I used it yesterday.
I have had this error before when I first installed rosserial but a simple search gave me the fix of adding a "." in front, but this time its a different problem and i don't see any other solutions. the only thing I have changed is my usb cable but i know it works since i uploaded code to the Arduino with it. I tried filling the rosserial_python.py files with random characters to see if the error would change but its always the same error.
Originally posted by ryleymcc on ROS Answers with karma: 26 on 2021-01-20
