My goal is to use the SLAM toolbox on ROS Noetic with a rosbag (recorded on ROS Melodic). When I launch the SLAM toolbox in one terminal and play the rosbag in another terminal and open RVIZ in a third terminal. I get the following warning message on the terminal that launches the slam toolbox:
Warning: TF_REPEATED_DATA ignoring data with redundant timestamp for frame odom at time 1609136889.260522 according to authority unknown_publisher at line 278 in /tmp/binarydeb/ros-noetic-tf2-0.7.5/src/buffer_core.cpp
I also get the following warning on the terminal that launches RVIZ :
[ WARN] [1609407684.995474563, 1609136889.060521646]: TF_REPEATED_DATA ignoring data with redundant timestamp for frame odom at time 1609136889.260522 according to authority unknown_publisher
My rosbag has the following topics published :
  1. /scan
  2. /odom
  3. /tf
Why do i get this warning and how can I get rid of it ?
Originally posted by ankurb on ROS Answers with karma: 1 on 2020-12-31
Comment by lucasw on 2021-09-26:
See #q381529 on how to suppress the warning
I now get the same with Cartographer ...
There is comment @ https://answers.ros.org/question/359968/tf_repeated_data-error-with-robot_localization-ukf-package/
and @ https://github.com/ros/geometry2/issues/467
Not sure these fix it tho ?
again any ideas ?
Originally posted by Slider with karma: 51 on 2021-02-24
I have the same problem, any fix for this?
