I am playing back a bag file and need to be able to move things around while the bag is on pause. I have an interactive marker that broadcasts its pose as a transform. I also have a laser scan in the frame of the marker's transform frame. RViz does update transform tree display and interactive marker, but the laser scan only moved to the new location when I resume the bag playback.
The laser scan is published by a node (not by the rosbag) based on wallclock. To force the RViz to update the scan I tried to change laser scan time stamp. I tried to publish to /clock myself, incrementing the timestamp while the bag is on pause (I remapped the rosbag's /clock). Nothing did work.
Edit: The laser scan I want to move in the rviz display is published with ros::wallTimer callback (frequency does not depend on simulation clock). It is stamped based on the last /clock message from the bag. I was hoping to figure out how to get the laser scan to be redrawn at the correct location according to updated tf tree, without resuming the bag playback.
The goal is to be able to get some measurements done on the recorded data using convenience of RViz infrastructure.
Originally posted by mmedvede on ROS Answers with karma: 221 on 2013-01-22
