Hello,
I want to display a laser scan data I have, file Mapping1.bag from a ROS tutorial(http://wiki.ros.org/laser_pipeline/Tutorials/IntroductionToWorkingWithLaserScannerData). When I run the bag file and try to display it on RVIZ with the right topic, I am having an error message :
"Transform [sender=unknown_publisher] For frame [base_laser_link]: Fixed Frame [map] does not exist"
LaserScan status is on ERROR and nothing is displayed.
Any idea about this problem ?
Originally posted by karl on ROS Answers with karma: 5 on 2018-12-17
Comment by allenh1 on 2018-12-17:
This means RVIZ cannot take the base_link_laser frame onto the map frame. Could you update your post with a link to the tutorial?
RVIZ is not showing the laser scan because the 'fixed frame' is set to map. The laser scan has a different coordinate frame and there is no known transformation between them.
To fix this you need to go to the world section in the top left of the RVIZ window and change the fixed frame to base_link_laser so that RVIZ is viewing in the laser's own coordinate frame, then this will start working.
Originally posted by PeteBlackerThe3rd with karma: 9529 on 2018-12-17
Comment by karl on 2018-12-18:
Thanks Pete, you were right but the fixed frame has to be : "base_laser_link" and not "base_link_laser" eheh :D
