When I try to use catkin_make, it fails at map_server.
I got the following message
CMake Error at /usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
  Could NOT find SDL (missing: SDL_LIBRARY SDL_INCLUDE_DIR)
  /usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
  /usr/share/cmake-3.10/Modules/FindSDL.cmake:190 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  navigation/map_server/CMakeLists.txt:12 (find_package)
See also "/home/ryosukeo/practice_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/ryosukeo/practice_ws/build/CMakeFiles/CMakeError.log".
Makefile:4688: recipe for target 'cmake_check_build_system' failed
make: *** [cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
What do I do to solve this problem
Originally posted by ryosukeo on ROS Answers with karma: 13 on 2019-12-25
sudo apt-get install libsdl-image1.2-dev and
sudo apt-get install libsdl-dev
These solve the issue.
Source
Also for melodic, you can use this to install other dependencies too. Enter your practice_ws directory and run this command:
rosdep install --from-paths src --ignore-src --rosdistro melodic -y
Originally posted by Orhan with karma: 856 on 2019-12-26
Comment by ryosukeo on 2019-12-27:
Thank you. this problem solved.
Comment by Orhan on 2019-12-27:
Then you can accept the answer as correct ( the tick mark is on the left of the answer, under the voting area)
Comment by gvdhoorn on 2019-12-27:
Related: #q252478.
Also, about your own packages, do not forget to add your dependencies to your CMakeLists.txt and package.xml. I've seen lots of packages which they don't have all dependencies listed. rosdep looks up for dependencies from your definitions in the package. Even if you are able to build your workspace, you might face with a runtime error when a dependent package isn't installed.
