Hi everyone,
Please give me some advices for this problem with ghost obstacles.
My mobile robot is working with ROS (Kinetic, Ubuntu 16.0.4) using Sick sensor. My robot uses 2 Sick sensor, one is in the right-upper corner and another one is in left-bottom corner. I use ira_laser_tools to merge data of these 2 laser scanners.
However, I am stucking at one problem: ghost obstacles appear on the costmap, and this ghost obstacle is relative to my mobile robot. If my robot moves, the ghost obstacle relatively follow. It causes mobile robot try to avoid obstacles even though there is no real obstacles.
I have tried to use some different laser-filter packages, but this problem still happen.
Can you please give me some suggestion ?
Thanks in advances
I took a video about my error (ghost obstacle) as in the link below:
https://www.youtube.com/watch?v=THt7oVjJsV8
And, the picture within the indication for ghost obstacles here:
And, the costmap configuration:
costmap_common_params:
footprint: [[0.44, 0.34], [0.44, -0.34], [-0.44, -0.34], [-0.44, 0.34] ]
footprint_padding: 0.0
transform_tolerance: 0.2
map_type: costmap
obstacle_layer:
enabled: true
obstacle_range: 1.5
raytrace_range: 3.0
inflation_radius: 0.2
track_unknown_space: true
combination_method: 1
min_obstacle_height: 0.1
max_obstacle_height: 0.5
observation_sources: laser_scan_sensor
laser_scan_sensor: {data_type: LaserScan, topic: scan, marking: true, clearing: true}
inflation_layer:
enabled: true
cost_scaling_factor: 10.0 # exponential rate at which the obstacle cost drops off (default: 10)
inflation_radius: 0.6 # max. distance from an obstacle at which costs are incurred for planning paths.
static_layer:
enabled: true
map_topic: "map"
rgbd_obstacle_layer:
enabled: true
voxel_decay: 0.4 #seconds if linear, e^n if exponential
decay_model: 0 #0=linear, 1=exponential, -1=persistent
voxel_size: 0.05 #meters
track_unknown_space: true #default space is unknown
observation_persistence: 0.0 #seconds
max_obstacle_height: 2.0 #meters
unknown_threshold: 15 #voxel height
mark_threshold: 0 #voxel height
update_footprint_enabled: true
combination_method: 1 #1=max, 0=override
obstacle_range: 2.0 #meters
origin_z: 0.0 #meters
publish_voxel_map: true # default off
transform_tolerance: 0.2 # seconds
mapping_mode: false # default off, saves map not for navigation
map_save_duration: 60 #default 60s, how often to autosave
observation_sources: rgbd1_clear rgbd1_mark rgbd2_clear rgbd2_mark
rgbd1_mark:
data_type: PointCloud2
topic: cam_1/depth/color/points
marking: true
clearing: false
min_obstacle_height: 0.15 #default 0, meters
max_obstacle_height: 2.0 #defaule 3, meters
expected_update_rate: 0 #default 0, if not updating at this rate at least, remove from buffer
observation_persistence: 0.0 #default 0, use all measurements taken during now-value, 0=latest
inf_is_valid: false #default false, for laser scans
clear_after_reading: true #default false, clear the buffer after the layer gets readings from it
voxel_filter: true #default off, apply voxel filter to sensor, recommend on
rgbd1_clear:
marking: false
clearing: true
min_z: 0.1 #default 0, meters
max_z: 7.0 #default 10, meters
vertical_fov_angle: 0.7 #default 0.7, radians
horizontal_fov_angle: 1.04 #default 1.04, radians
decay_acceleration: 1. #default 0, 1/s^2. If laser scanner MUST be 0
model_type: 0 #default 0 (depth camera). Use 1 for 3D Lida
rgbd2_mark:
topic: cam_2/depth/color/points
marking: true
clearing: false
rgbd2_clear:
marking: false
clearing: true
global costmap
global_costmap:
global_frame: map
robot_base_frame: base_footprint
update_frequency: 5
publish_frequency: 2
static_map: true
transform_tolerance: 0.5
plugins:
- {name: static_layer, type: "costmap_2d::StaticLayer"}
- {name: obstacle_layer, type: "costmap_2d::ObstacleLayer"}
- {name: rgbd_obstacle_layer, type: "spatio_temporal_voxel_layer/SpatioTemporalVoxelLayer"}
- {name: inflation_layer, type: "costmap_2d::InflationLayer"}
local costmap
local_costmap:
global_frame: map
robot_base_frame: base_link
update_frequency: 15
publish_frequency: 5
static_map: false
rolling_window: true
width: 4
height: 4
resolution: 0.1
plugins:
sonar_layer:
topics: ['sonar_0',
'sonar_1',
'sonar_2',
'sonar_3',
'sonar_4',
'sonar_5',
'sonar_6',
'sonar_7']
Do you have any ideas about these ?
Thank you so much
Originally posted by Getchbold NT on ROS Answers with karma: 36 on 2019-04-24
Comment by mgruhler on 2019-04-24:
I guess it would help to see an image of your problem, as well as a description of what is there "in the real world". Also, maybe share your costmap configuration. That the obstacle is moving with the robot is suggesting that it is continuously seen by the scanner. Can you verify this?
I've come across this in multiple scenarios:
- self measurement of the robot
- "ghost pixels" due to veiling effect (
ScanShadowsFilter
can help there) - bad configuration of
obstacle_range
andraytrace_range
- discretization effects in the
obstacle_layer
maybe it can be narrowed down to one of those?
Comment by Getchbold NT on 2019-04-24:
Thank mgruhler so much for your quick help, I will prepare those kinds of data and update soon
Comment by gvdhoorn on 2019-04-25:
@Getchbold NT: please attach your screenshot directly to the question. I've given you sufficient karma.
Comment by Getchbold NT on 2019-04-25:
Thank you so much @gvdhoorn
I updated the video and picture about error and cost_map configuration @mgruhler
Comment by mgruhler on 2019-04-25:
quite obviously, the laser scanner is actually measuring something there. So the costmap is actually doing what it is supposed to.
So you need to figure out where those readings are coming from.
- actual measurement: Remove what the LiDAR is seeing there (I know, obvious :-))
- self-measurement of the robot: mount the LiDAR differently or filter the ranges where you are hitting the robot with the laser beam
- veiling effect (i.e. hitting "edges" with one beam): judging from the image/video, this could actually be the case
- other effects, like strong reflection (mirror, glas?) could also lead to those readings.
If this is a problem that occurs that often, you might probably have to use a laser filter to get rid of those (single point) measurements. The ScanShadowsFilter can really help there.
What sensor are you using exactly?
@mgruhler thank you so much for your answer
I am using Sick sensor.
Our laboratory does not has mirror and glass.
This problem now always happen, I cannot know how to solve this problem. I am quite new with lidar sensor and laser filter. Can you please tell me clearly how to use ScanShadowsFilter to remove these single points?.
I can see this configuration of ScanShadowsFilter, but I do not actually whether this shadow_filter is called or not ?
scan_filter_chain:
type: ScanShadowsFilter
params:
min_angle: 5
max_angle: 175
neighbors: 1
window: 1
type: LaserScanIntensityFilter
params:
lower_threshold: 100
upper_threshold: 50000
disp_histogram: 0
The costmap configuration is used as default, I did not change anything
Thank you so much
Yes, a Sick sensor, but which model? LMSXXX? S300? S3000? MSR? Seeing that the scan is actually 360°, it is non of the former, but maybe an MSR?
There is a tutorial describing the ScanShadowsFilter. Then you obviously need to fix the remappings in the respective nodes. Please update your question (or post a new one) if you have troubles with setting this up...
Yes, the model of Sick sensor which i am using is: TIM551.
Comment by Getchbold NT on 2019-04-29:
Hi @mgruhler: I have used ScanShadowsFilter however, the error still happen. This is the parameters for ScanShadowsFilter:
scan_filter_chain:
- name: box_filter
type: laser_filters/LaserScanBoxFilter
params:
box_frame: R_007/base_link
max_x: 0.438
max_y: 0.332
max_z: 0.231
min_x: -0.438
min_y: -0.332
min_z: -0.01
params:
min_angle: 5
max_angle: 175
neighbors: 5
window: 1
type: LaserArrayFilter
params:
range_filter_chain:
- name: median_3 type: filters/MultiChannelMedianFilterFloat params: number_of_observations: 3 unused: 6
intensity_filter_chain:
Comment by Getchbold NT on 2019-05-02:
I also tried to use LaserScanIntensityFilter, increase the values of raytrace_range, however the problem still happened. My robot uses 2 laser sensor, one is in right upper corner, another one is on left bottom corner. I used ira_laser_tools to merge data of 2 laser scanners
Comment by pavel92 on 2019-05-03:
The video link that you posted is also unavailable
Comment by gvdhoorn on 2019-05-03:
@Getchbold NT: why did you remove the video? Your question has lost a great deal of its value now.
