Hi,
I tried to visualize the costmap in RVIZ. The local costmap is published and visualized, while the global costmap doesn't publish any data. Since RVIZ is able to find the global costmap topic, I assume that it is advertised but no data are transmitted (no messages are received).
I use the following configuration:
- cost_scaling_factor: 10.0
- footprint: '[]'
- global_frame: /map
- height: 20
- inflation_radius: 0.5
- lethal_cost_threshold: 100
- map_topic: map
- map_type: costmap
- mark_threshold: 0
- max_obstacle_height: 0.6
- max_obstacle_range: 20
- observation_sources: scan
- obstacle_range: 20
- origin_x: 0.0
- origin_y: 0.0
- origin_z: 0.0
- publish_frequency: 1.0
- publish_voxel_map: false
- raytrace_range: 3.0
- resolution: 0.05
- restore_defaults: false
- robot_base_frame: /base_footprint
- robot_radius: 0.18
- rolling_window: false
- scan: {clearing: true, data_type: LaserScan, marking: true, topic: /scan}
- static_map: true
- track_unknown_space: true
- transform_tolerance: 0.5
- unknown_cost_value: 255
- unknown_threshold: 255
- update_frequency: 1.0
- width: 20
- z_resolution: 0.2
- z_voxels: 10
Hopefully someone could help or give me a hint.
Thanks, Daniel
Originally posted by dneuhold on ROS Answers with karma: 205 on 2013-09-25
Comment by Hendrik Wiese on 2013-09-25:
Not sure about this, but have you tried setting publish_voxel_map to true?
Comment by dneuhold on 2013-09-26:
Unfortunately the global_costmap is still not published! I appreciate every hint or idea to visualize it in rviz.
Comment by Hendrik Wiese on 2013-09-26:
What I meant with my (deleted) comment was: could you provide the whole costmap configuration file as it is. Not just the settings as they should be. Maybe there's another namespace issue...
Comment by David Lu on 2013-09-27:
What is the global topic you are listening on?
Comment by dneuhold on 2013-09-29:
The topic I am listening on is: /move_base/global_costmap/obstacles
The topic is "ok" (in rviz) but no messages are received. There is also no namespace issue, I checked every parameter twice.
Thanks to all of you
Comment by dornhege on 2013-09-30:
You might want to check that the publish_frequency is > 0.0 for the global costmap, when running the system. The safest way would be to dump the params, while it's running, so you see what's really going on.
Comment by David Lu on 2013-09-30:
Which version of ROS are you using?
Comment by dneuhold on 2013-09-30:
I use ROS groovy!
Can you visualize costmap/unknown_space?
Yes, I am able to visualize all topics from the local_costmap (obstacles, unknown space and inflated_obstacles) but nothing from the global_costmap!
So global_costmap/unknown_space is empty as well?
Exactly, it is empty as well.
Comment by David Lu on 2013-10-01:
Can you run rosparam get /move_base and post the output on pastebin, please?
