Hello,
I am currently trying to use the navsat_transform_node from the robot_localization package in a ROS-Gazebo simulation. I'm using Ubuntu 16.04 LTS, with ROS kinetic and Gazebo 7.
In order to work, this node needs to subscribe to 3 differents topics : an odometry topic with nav_msgs/Odometry message, an IMU topic with sensor_msgs/Imu and a GPS topic with sensor_msgs/NavSatFix.
My problem is that, when launching the navsat_transform_node does not subscribe to my IMU topic, even if the message type of the IMU topic published by gazebo is sensor_msgs/Imu. However, the node does subscribe to the odom and gps topics.
Here is my launch file (taken from the robot localization wiki) :
<?xml version="1.0" encoding="UTF-8"?>
<launch>
  <node pkg="robot_localization" type="navsat_transform_node" name="navsat_transform_node" respawn="true">
    <param name="magnetic_declination_radians" value="0"/>
    <param name="yaw_offset" value="0"/>
    <remap from="/imu/data" to="/imu_data" />
    <remap from="/gps/fix" to="/gps/fix" />
    <remap from="/odometry/filtered" to="/odom" />
  </node>
</launch>
Here is the IMU code from the URDF file of my robot model :
  <joint name="imu_joint" type="fixed">
    <axis xyz="0 0 1"/> <!-- 0 1 0 -->
    <origin xyz="${length_chassis*(5/16)} 0 ${height_chassis-(wheel_radius/2)}"/>
    <parent link="base_link"/>
    <child link="imu_link"/>
  </joint>
<link name="imu_link">
  <inertial>
    <mass value="0.001"/>
    <origin rpy="0 0 0" xyz="0 0 0"/>
    <inertia ixx="0.0001" ixy="0" ixz="0" iyy="0.000001" iyz="0" izz="0.0001"/>
  </inertial>
  <visual>
    <geometry>
      <box size=" ${IMU_size} ${IMU_size} ${IMU_size}"/>
    </geometry>
    <material name="green"/>
  </visual>
  <collision>
    <geometry>
      <box size="${IMU_size} ${IMU_size} ${IMU_size}"/>
    </geometry>
  </collision>
</link>
And here is the IMU plugin :
<gazebo >
    <plugin name="imu_plugin" filename="libhector_gazebo_ros_imu.so">
      <alwaysOn>true</alwaysOn>
      <bodyName>imu_link</bodyName>
      <frameId>imu_link</frameId>
      <topicName>/imu_data</topicName>
      <serviceName>imu_service</serviceName>
      <gaussianNoise>0.0</gaussianNoise>
      <updateRate>20.0</updateRate>
      <xyzOffsets>0 0 0</xyzOffsets>
      <rpyOffsets>0 0 0</rpyOffsets>
    </plugin>
</gazebo>
When echo-ing the topic /imu_data, I get :
header:
  seq: 327
  stamp:
    secs: 16
    nsecs: 400000000
  frame_id: "imu_link"
orientation:
  x: 4.69962116857e-06
  y: -4.8838604247e-08
  z: 7.97720664175e-05
  w: 0.999999996807
orientation_covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
angular_velocity:
  x: -4.49165569326e-13
  y: 6.43295283435e-15
  z: 2.52244385042e-12
angular_velocity_covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
linear_acceleration:
  x: 3.40118210419e-07
  y: 9.18946096526e-05
  z: 9.79999999084
linear_acceleration_covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
Also, @Tom Moore told me to post a sample message for every sensor input, so here is the sample from the topic /odom :
header:
  seq: 165673
  stamp:
    secs: 1661
    nsecs: 260000000
  frame_id: "odom"
child_frame_id: "base_link"
pose:
  pose:
    position:
      x: 0.267229286097
      y: 0.00580914153162
      z: 0.299999489939
    orientation:
      x: 1.20893461539e-05
      y: -8.60155713043e-08
      z: 0.0124744407312
      w: 0.999922191064
  covariance: [1e-05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.001]
twist:
  twist:
    linear:
      x: 0.000281084109386
      y: -4.7415432993e-06
      z: 0.0
    angular:
      x: 0.0
      y: 0.0
      z: 1.31254728036e-05
  covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
And here, the sample from the /gps/fix topic :
header:
  seq: 7159
  stamp:
    secs: 1794
    nsecs: 500000000
  frame_id: "GPS_link"
status:
  status: 0
  service: 0
latitude: -30.0602189385
longitude: -51.1739172289
altitude: 9.7517203133
position_covariance: [0.0025010000000000006, 0.0, 0.0, 0.0, 0.0025010000000000006, 0.0, 0.0, 0.0, 0.0025010000000000006]
position_covariance_type: 2
If you have any ideas on how to fix this issue, I will be pleased ! Thank you
EDIT after @cagatayyuruk answer :
  • changed the plugin of my IMU from libgazebo_ros_imu.so to libhector_gazebo_ros_imu.so because the old one was not able to get imu_link as frame id. (code of the IMU and sample of the IMU's message are updated in the text above)
  • after a few test, it seems that the navsat node can only subscribe to the IMU topic when the TF_static between IMU_link and base_link is not set. So when all the tf static of the robot are launched, the navsat node does not work. Maybe I got something wrong in my TF that stop the subscribe of the navsat node to the IMU topic ?
EDIT for the TF Tree on Imgur : https://imgur.com/mVl7iCG
Originally posted by antonin_haulot on ROS Answers with karma: 215 on 2018-03-30
Comment by stevejp on 2018-04-03:
I'm a little suspicious that it has something to do with your TFs. If you could post your TF tree (without trying to run navsat transform) that would be useful.
Comment by antonin_haulot on 2018-04-04:
I can not post image since I do not have enough karma point to upload a file
Comment by l4ncelot on 2018-04-04:
Upload it somewhere else and post the link here.
A couple things:
  1. Your IMU data has a frame_id of imu_link, and your GPS has a frame_id of GPS_link. You need to define static transforms from imu_link -> base_link and from gps_link to base_link.
  2. Keep in mind that, once navsat_transform_node gets a single usable IMU message, it unsubscribes from the IMU data. It only needs a single earth-referenced heading measurement.
Originally posted by Tom Moore with karma: 13689 on 2018-04-09
Post score: 8
Comment by antonin_haulot on 2018-04-13:
Thank you for your answer. It seems that with the correct static transforms, the node is working fine !
Comment by Jimeat on 2018-07-26:
What is the best way to get earth referenced heading measurement from IMU?
Comment by Tom Moore on 2018-08-03:
Please ask a separate question.
Comment by A.Mahrous on 2019-09-30:
could you please tell me how you solved this in details?, thanks in advance.
Comment by atwin on 2020-06-10:
can you please show the launch file with the correct static transforms. I seem to have this exact same issue and have tried to write static transforms for both base_link -> imu_link and base_link -> gps (my GPS frame_id--from bag1) only to gain no result.
Comment by Delbina on 2022-03-22:
@Tom Moore hi, regardin the first point which you mentioned, in the tf tree i can see that gps and imu link through a number of other links are connected to the base_link. i have also checked the tf between gps_link to base_link AND imu_link -> base_link. it starts publishing. so in this case d i need to define the static transforms again??
thanks
Comment by Tom Moore on 2022-04-08:
Please ask a new question.
