According to tutorial about GPS Integration and use of navsat transform node, i put into node the imu with absolute heading values, odometry that is the output of second instance of EKF and NavSatFix message.
The problem is that the node doesn't publish any data in /odometry/gps. I check the covariances of IMU and odometry message. I check also the value of lat/lon/h of GPS message because I have readed that one of this is NaN the navsat_transform node doesn't make output.
So, what is my fault?
UPDATE 16-03-2016 Bagfile: https://drive.google.com/file/d/0B_1fqLQnQO6oVWszVnM2SWs3OE0/view?usp=sharing
Roslaunch navsat_node: https://drive.google.com/file/d/0B_1fqLQnQO6oZ0JGUlQwbllqUjA/view?usp=sharing
UPDATE 23-01-2017 Roslaunch navsat_node: https://github.com/NikoGiovannini/nostop_launch_files/blob/c9294d3a64973a4a272f546d417d3989e876d10a/launch/arduino/PC_robot_green_yellow.launch
Originally posted by Niko on ROS Answers with karma: 33 on 2016-03-08
Comment by Tom Moore on 2016-03-08:
Please post a sample message for all inputs, as well as your navsat_transform_node configuration.
The error was in the wrong frame id of the imu message. I corrected it and now the navsat transform work properly. Begineer mistake.
Originally posted by Niko with karma: 33 on 2016-03-17
Comment by sonyccd on 2016-06-22:
Could you explain what you mean by this a little more. I think I am having the same problem.
Comment by shoemakerlevy9 on 2016-10-04:
Yes I'd also like to know more about how you fixed this. I am having the same issue. My Frame ID's are as follows: IMU: base_link Encoders: odom GPS: gps
Comment by modotz on 2017-01-23:
I have the same problem, could you please upload the corrected files?
