Hello,
I followed the tutorial on how to add a gps sensor to robot_pose_ekf (http://ros.org/wiki/robot_pose_ekf/Tutorials/AddingGpsSensor), but the filter is not outputing any message. My gps messages are published on the /vo topic. Here's the output when I run wtf.py.
Input:
 * Odometry sensor
   - is NOT active
   - received 0 messages
   - listens to topic
 * IMU sensor
   - is NOT active
   - listens to topic /imu_data
 * Visual Odometry sensor
   - is active
   - received 124 messages
   - listens to topic /gps_meas
Output:
 * Robot pose ekf filter
   - is active
   - sent 0 messages
   - pulishes on topics /robot_pose_ekf/odom_combined and /tf
I mapped the /vo topic to /gps_meas.
And here's an example of my gps message when I rostopic echo /gps_meas:
header:
  seq: 10261
  stamp:
    secs: 1354823750
    nsecs: 691171604
  frame_id: base_footprint
child_frame_id: base_link
pose:
  pose:
    position:
      x: 0.0
      y: 0.0
      z: 0.0
    orientation:
      x: 0.0
      y: 0.0
      z: 0.0
      w: 1.0
  covariance: [1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1.0]
twist:
  twist:
    linear:
      x: 0.0
      y: 0.0
      z: 0.0
    angular:
      x: 0.0
      y: 0.0
      z: 0.0
Any idea why there's 0 message output? Thanks!!
Originally posted by xylo on ROS Answers with karma: 184 on 2012-12-06
Comment by sai on 2013-05-19:
I guess that u r not recieving any GPS signals..can you just test your gps with gpsd client and verify if u r getting the messages.
So I figured it out. I was receiving gps messages, but they were published in the wrong frames. They should be in the "odom_combined" header frame, and "base_footprint" child frame. Also somehow the timestamps of the gps messages had a big offset and were very different from the imu timestamps. After I corrected these two problems, robot_pose_ekf is working properly.
Originally posted by xylo with karma: 184 on 2013-05-20
