I am unable to solve this problem. I tried to run catkin_make command in catkin_ws directory.
yograj@yograj-Inspiron-5537:~/catkin_ws$ catkin_make
Base path: /home/yograj/catkin_ws
Source space: /home/yograj/catkin_ws/src
Build space: /home/yograj/catkin_ws/build
Devel space: /home/yograj/catkin_ws/devel
Install space: /home/yograj/catkin_ws/install
#### Running command: "cmake /home/yograj/catkin_ws/src -DCATKIN_DEVEL_PREFIX=/home/yograj/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/yograj/catkin_ws/install -G Unix Makefiles" in "/home/yograj/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/yograj/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/kinetic
-- This workspace overlays: /opt/ros/kinetic
-- Using PYTHON_EXECUTABLE: /home/yograj/anaconda2/bin/python
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/yograj/catkin_ws/build/test_results
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- Using Python nosetests: /usr/bin/nosetests-2.7
ImportError: "from catkin_pkg.package import parse_package" failed: No module named catkin_pkg.package
Make sure that you have installed "catkin_pkg", it is up to date and on the PYTHONPATH.
CMake Error at /opt/ros/kinetic/share/catkin/cmake/safe_execute_process.cmake:11 (message):
  execute_process(/home/yograj/anaconda2/bin/python
  "/opt/ros/kinetic/share/catkin/cmake/parse_package_xml.py"
  "/opt/ros/kinetic/share/catkin/cmake/../package.xml"
  "/home/yograj/catkin_ws/build/catkin/catkin_generated/version/package.cmake")
  returned error code 1
  /opt/ros/kinetic/share/catkin/cmake/catkin_package_xml.cmake:74 (safe_execute_process)
  /opt/ros/kinetic/share/catkin/cmake/all.cmake:151 (_catkin_package_xml)
  /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:20 (include)
  CMakeLists.txt:52 (find_package)
See also "/home/yograj/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/yograj/catkin_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
Originally posted by Nebula on ROS Answers with karma: 98 on 2018-02-02
From @tfoote's answer for a very similar question:
to use Anaconda you will need to do a lot with your PYTHONPATH to make sure that all dependencies are on the path that Anaconda's interpreter is using.
I would recommend trying to find a way to use anaconda separately/in parallel with your anaconda installation. The main problem is that Anaconda doesn't use the standard installed python libraries so often you end up with missing resources.
Originally posted by jayess with karma: 6155 on 2018-02-02
Comment by Nebula on 2018-02-02:
I solved by following similar problem.
with using
pip install -U rosdep rosinstall_generator wstool rosinstall six vcstools
Comment by jayess on 2018-02-02:
Great, but please don't use a comment to provide an answer, that's what answers are for.
with using
Originally posted by Nebula with karma: 98 on 2018-02-02
