Hello I am trying to build a package 'gruvy_usarsim_inf' by using catkin workspace. I have set the dependencies also; but when I type in the terminal "catkin_make" following error comes.
root@ubuntu:~/catkin_ws# catkin_make
Base path: /root/catkin_ws
Source space: /root/catkin_ws/src
Build space: /root/catkin_ws/build
Devel space: /root/catkin_ws/devel
Install space: /root/catkin_ws/install
Running command: "make cmake_check_build_system" in "/root/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /root/catkin_ws/devel -- Using CMAKE_PREFIX_PATH: /opt/ros/groovy -- This workspace overlays: /opt/ros/groovy -- Using Debian Python package layout -- Using CATKIN_ENABLE_TESTING: ON -- Call enable_testing() -- Using CATKIN_TEST_RESULTS_DIR: /root/catkin_ws/build/test_results -- Found gtest: gtests will be built -- catkin 0.5.71 -- BUILD_SHARED_LIBS is on -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -- ~~ traversing 1 packages in topological order: -- ~~ - gruvy_usarsim_inf -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -- +++ processing catkin package: 'gruvy_usarsim_inf' -- ==> add_subdirectory(gruvy_usarsim_inf) CMake Error at /opt/ros/groovy/share/catkin/cmake/catkinConfig.cmake:72 (find_package): Could not find a configuration file for package control_msgs.
Set control_msgs_DIR to the directory containing a CMake configuration file for control_msgs. The file will have one of the following names:
control_msgsConfig.cmake
control_msgs-config.cmake
Call Stack (most recent call first): gruvy_usarsim_inf/CMakeLists.txt:7 (find_package)
CMake Error at /opt/ros/groovy/share/catkin/cmake/catkinConfig.cmake:72 (find_package): Could not find a configuration file for package nav_msgs.
Set nav_msgs_DIR to the directory containing a CMake configuration file for nav_msgs. The file will have one of the following names:
nav_msgsConfig.cmake
nav_msgs-config.cmake
CMake Error at /opt/ros/groovy/share/catkin/cmake/catkinConfig.cmake:72 (find_package): Could not find a configuration file for package sensor_msgs.
Set sensor_msgs_DIR to the directory containing a CMake configuration file for sensor_msgs. The file will have one of the following names:
sensor_msgsConfig.cmake
sensor_msgs-config.cmake
CMake Error at /opt/ros/groovy/share/catkin/cmake/catkinConfig.cmake:72 (find_package): Could not find a configuration file for package tf.
Set tf_DIR to the directory containing a CMake configuration file for tf. The file will have one of the following names:
tfConfig.cmake
tf-config.cmake
-- Configuring incomplete, errors occurred! make: *** [cmake_check_build_system] Error 1 Invoking "make cmake_check_build_system" failed
Originally posted by RB on ROS Answers with karma: 229 on 2013-09-12
You have to install that dependency depending on what version you have. If you have Indigo and below you can do it through apt-get. If you're running jade or higher then you have to build from source.
Here are some command to try :
sudo rosdep init rosdep update sudo rosdep install --from-paths src --ignore-src --rosdistro jade -y
Originally posted by spottybadrabbit with karma: 36 on 2016-08-10
Comment by MTDzi on 2018-06-13:
This worked for me (+1).
Just one correction: it's not a single command, it should be split into three:
sudo rosdep init
rosdep update
