hi,I'm trying to build native ROS nodes using the Android NDK by this tutorial[http://wiki.ros.org/android_ndk/Tutorials/BuildingNativeROSPackages]. I use Ubuntu 64bit 14.04LTS as the host on the VM. I installed docker by step 1 and step 2 successfully and run ./do_docker.sh cmd,then something goes wrong with this:
[ 84%] Building CXX object modules/ts/CMakeFiles/opencv_ts.dir/src/ts.cpp.o
Linking CXX static library ../../lib/libopencv_ts.a
[ 84%] Built target opencv_ts
[ 84%] Generating OpenCV Android library project. SDK target: lib_target_sdk_target-NOTFOUND
make[2]: *** [build.xml] Error 1
make[1]: *** [modules/java/CMakeFiles/opencv_java.dir/all] Error 2
make: *** [all] Error 2
Cross-compiling ROS.
Running catkin_make.
Base path: /opt/roscpp_output/catkin_ws
Source space: /opt/roscpp_output/catkin_ws/src
Build space: /opt/roscpp_output/catkin_ws/build
Devel space: /opt/roscpp_output/catkin_ws/devel
Install space: /opt/roscpp_output/target
Then the cmake comeout some errors :
CMake Error at catkin/cmake/catkin_workspace.cmake:95 (message):
  This workspace contains non-catkin packages in it, and catkin cannot build
  a non-homogeneous workspace without isolation.  Try the
  'catkin_make_isolated' command instead.
  CMakeLists.txt:63 (catkin_workspace)
See also "/opt/roscpp_output/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/opt/roscpp_output/catkin_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
Installing.
make: *** No rule to make target `install'.  Stop.
build_cpp.sh /opt/roscpp_output died with error code 2
Creating output/roscpp_android_ndk.tar.gz.
tar: roscpp_android_ndk: Cannot stat: No such file or directory
tar: Exiting with failure status due to previous errors
the CMakeError.log shows like :
CheckIncludeFile.c:1:22: fatal error: execinfo.h: No such file or directory
compilation terminated.
make[1]: Leaving directory `/opt/roscpp_output/catkin_ws/build/CMakeFiles/CMakeTmp'
make[1]: *** [CMakeFiles/cmTryCompileExec2484976465.dir/CheckIncludeFile.c.o] Error 1
make: *** [cmTryCompileExec2484976465/fast] Error 2
and
/opt/roscpp_output/catkin_ws/build/CMakeFiles/CMakeTmp/src.cxx:2:8: error: expected constructor, destructor, or type conversion before '(' token
make[1]: *** [CMakeFiles/cmTryCompileExec640946834.dir/src.cxx.o] Error 1
make: *** [cmTryCompileExec640946834/fast] Error 2
main:CheckFunctionExists.c(.text.main+0x14): error: undefined reference to 'backtrace'
collect2: ld returned 1 exit status
make[1]: *** [cmTryCompileExec4272716319] Error 1
make: *** [cmTryCompileExec4272716319/fast] Error 2
I don't know if the cmake errors come from the opencv errors. Any one Know something about this problem?Thanks a lot!
Originally posted by xy1zzz on ROS Answers with karma: 26 on 2015-11-21
Comment by Gary Servin on 2015-11-25:
It seems like opencv is failing to build, I just cleaned my workspace and started a new do_docker from scratch to see if I can reproduce this issue. I'll let you know.
Comment by xy1zzz on 2015-11-25:
Thanks a lot !
Comment by Gary Servin on 2015-11-26:
It seems it failed to install correctly the Android SDK inside the container, thus the "SDK target: lib_target_sdk_target-NOTFOUND".
Can you manually install the SDK again inside the container? Here are the instructions: https://gist.github.com/garyservin/34bea53e53690ccc966d
Comment by xy1zzz on 2015-11-26:
THANKS,I'm trying
Comment by xy1zzz on 2015-11-27:
I have delete all docker images,and reinstall again,and the problem shows again:"SDK target: lib_target_sdk_target-NOTFOUND"
I have checked the docker images by your advice in ”https://gist.github.com/garyservin/34bea53e53690ccc966d“,and rosndk and android sdk is ok.
then I echo $PATH shows:/usr/lib/ccache:/opt/android-sdk-linux/tools:/opt/android-sdk-linux/platform-tools:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
echo $ANDROID_HOME shows:/opt/android-sdk-linux
seems ok?
maybe the step 27 have something wrong,I'm trying
I found some in opencv build: -- Android: -- Android ABI: armeabi-v7a -- STL type: gnustl_static -- Native API level: android-14 -- SDK target: android_sdk_target_status-NOTFOUND
do I need install android API 14?
Comment by xy1zzz on 2015-11-28:
still shows the same problem SDK target: lib_target_sdk_target-NOTFOUND
Comment by Gary Servin on 2015-11-30:
I've upload my rosndk image for now, can you try using it instead of building? https://hub.docker.com/r/garyservin/rosndk/
Comment by xy1zzz on 2015-11-30:
Thanks so much,I have build successfully by your previous suggestion.It's the Android SDK update errors,I'm writing the answer.
Thanks to Gary Servin I have build successfully by the following steps:
1.# Check if you have the rosndk image on the list.
u64@u64-VirtualBox:~$ docker images
REPOSITORY          TAG                 IMAGE ID            CREATED             VIRTUAL SIZE
rosndk              latest              6c374bc001d0        12 hours ago        3.678 GB
2.# This will create a container based on the image
u64@u64-VirtualBox:~$ docker run -it rosndk bash
root@58dfb6a0a9f4:/#
3.# run ls -l,you should have -rw-r--r-- 1 root root 140827643 Jul 2 2014 android-sdk_r23.0.2-linux.tgz
root@58dfb6a0a9f4:/# ls -l
total 593516
-rw-r--r--   1 root root 466853553 Mar 21  2013 android-ndk-r8e-linux-x86_64.tar.bz2
#if not
#run:wget http://dl.google.com/android/android-sdk_r23.0.2-linux.tgz
#and run :tar -xvf android-sdk_r23.0.2-linux.tgz -C /opt
4.#run android list and if the android target have been update successfully it should be like this:
root@58dfb6a0a9f4:/# android list
Available Android targets:
id: 1 or "android-20"
#if wrong, there are not any targets list,maybe the same question,then goto step 5.
5.#check if you can update android sdk successfully
(Thanks to the GREETWALL I cannot visit google without VPN).
root@58dfb6a0a9f4:/# android update sdk -u -t 2,3,7,8,9,11,13,16,56,57
6.#when update successfully,run exit.
root@58dfb6a0a9f4:/#exit
7.# Commit the latest container to rosndk
u64@u64-VirtualBox:~$docker commit $(docker ps -aq | head -n 1) rosndk
8.#delete the wrong build package #mine is:/home/u64/ros-android-ndk/roscpp_android/output/catkin_ws/src/vision_opencvzs
9.just run ./do_docker.sh again
u64@u64-VirtualBox:~/ros-android-ndk/roscpp_android$ ./do_docker.sh
#when you are success,it shows:
summary of what just happened:
  target/      was used to build static libraries for ros software
    include/   contains headers
    lib/       contains static libraries
  roscpp_android_ndk/     is a NDK sub-project that can be imported into an NDK app
  sample_app/  is an example of such an app, a native activity
  sample_app/bin/sample_app-debug.apk  is the built apk, it implements a subscriber and a publisher
  move_base_sample_app/  is an example app that implements the move_base node
  move_base_app/bin/move_base_app-debug.apk  is the built apk for the move_base example
GOOD LUCK! THANKS TO GRAY SERVIN'S HELP!
Originally posted by xy1zzz with karma: 26 on 2015-11-30
