Hi all!
I'm trying to use UWSim and did eveything on the webpage. The problem now is that when I do:
rosmake UWSim --rosdep-install
I get the following error:
  [rosbuild] Including /opt/ros/electric/stacks/ros_comm/clients/rospy/cmake/rospy.cmake
  [rosbuild] Including /opt/ros/electric/stacks/ros_comm/clients/roslisp/cmake/roslisp.cmake
  [rosbuild] Including /opt/ros/electric/stacks/ros_comm/clients/cpp/roscpp/cmake/roscpp.cmake
  -- Configuring done
  -- Generating done
  CMake Warning:
    Manually-specified variables were not used by the project:
      CMAKE_TOOLCHAIN_FILE
  -- Build files have been written to: /home/albert/ros_electric/underwater_simulation/UWSim/build
  cd build && make -l2
  make[1]: Entering directory `/home/albert/ros_electric/underwater_simulation/UWSim/build'
  make[2]: Entering directory `/home/albert/ros_electric/underwater_simulation/UWSim/build'
  make[3]: Entering directory `/home/albert/ros_electric/underwater_simulation/UWSim/build'
  make[3]: Leaving directory `/home/albert/ros_electric/underwater_simulation/UWSim/build'
  [  0%] Built target rospack_genmsg_libexe
  [  0%] Built target rosbuild_precompile
  Linking CXX executable ../bin/UWSim
  /usr/bin/ld: warning: libosg.so.65, needed by /home/albert/ros_electric/underwater_simulation/osgOcean/lib/libosgOcean.so, not found (try using -rpath or -rpath-link)
  /usr/bin/ld: warning: libosgUtil.so.65, needed by /home/albert/ros_electric/underwater_simulation/osgOcean/lib/libosgOcean.so, not found (try using -rpath or -rpath-link)
  /usr/bin/ld: warning: libosgDB.so.65, needed by /home/albert/ros_electric/underwater_simulation/osgOcean/lib/libosgOcean.so, not found (try using -rpath or -rpath-link)
  /usr/bin/ld: warning: libosgGA.so.65, needed by /home/albert/ros_electric/underwater_simulation/osgOcean/lib/libosgOcean.so, not found (try using -rpath or -rpath-link)
  /usr/bin/ld: warning: libOpenThreads.so.13, needed by /home/albert/ros_electric/underwater_simulation/osgOcean/lib/libosgOcean.so, not found (try using -rpath or -rpath-link)
  /home/albert/ros_electric/underwater_simulation/osgOcean/lib/libosgOcean.so: undefined reference to `OpenThreads::Mutex::Mutex()'
  /home/albert/ros_electric/underwater_simulation/osgOcean/lib/libosgOcean.so: undefined reference to `osgDB::readImageFile(std::basic_string, std::allocator > const&, osgDB::ReaderWriter::Options const*)'
  collect2: ld returned 1 exit status
  make[3]: *** [../bin/UWSim] Error 1
  make[2]: *** [CMakeFiles/UWSim.dir/all] Error 2
  make[2]: Leaving directory `/home/albert/ros_electric/underwater_simulation/UWSim/build'
  make[1]: *** [all] Error 2
  make[1]: Leaving directory `/home/albert/ros_electric/underwater_simulation/UWSim/build'
From which I asume osg lib is missing. I've checked on google how to install it but no result found.
Can somebody give me a hint on how to solve it??
Cheers!
Originally posted by apalomer on ROS Answers with karma: 318 on 2012-06-06
Did you recently upgrade your distro? You have installed openscenegraph 3.0, which should link against libosg.so.80. However, your osgOcean seems to be compiled against libosg.so.65. Have you tried to pre-clean your build?
rosmake --pre-clean UWSim
Originally posted by Mario Prats with karma: 291 on 2012-06-07
Comment by apalomer on 2012-06-07:
it worked! thanks mario
Comment by Mario Prats on 2012-06-07:
great! you're welcome
