I am working through the Stage Simulating One Robot tutorial, but am having trouble compiling teleop_base. I had to change the default directories in several places, and am now stuck with errors in the cmake files related to boost (at least, this is what I gather from the output). Here is the end of the results from running "rosmake teleop_base":
rosmake ] Last 40 linesleop_base: 2.1 sec ] [ 1 Active 42/43 Complete ]
cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=rospack find rosbuild/rostoolchain.cmake ..
[rosbuild] Building package teleop_base
[rosbuild] Including /opt/ros/electric/stacks/ros_comm/clients/rospy/cmake/rospy.cmake
[rosbuild] Including /opt/ros/electric/stacks/ros_comm/clients/roslisp/cmake/roslisp.cmake
[rosbuild] Including /opt/ros/electric/stacks/ros_comm/clients/cpp/roscpp/cmake/roscpp.cmake
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
-- Build files have been written to: /opt/ros/electric/stacks/teleop_base/build
cd build && make -l4
make[1]: Entering directory `/opt/ros/electric/stacks/teleop_base/build'
make[2]: Entering directory `/opt/ros/electric/stacks/teleop_base/build'
make[3]: Entering directory `/opt/ros/electric/stacks/teleop_base/build'
make[3]: Leaving directory `/opt/ros/electric/stacks/teleop_base/build'
[ 0%] Built target rospack_genmsg_libexe
[ 0%] Built target rosbuild_precompile
[ 50%] Built target teleop_base
[100%] Building CXX object CMakeFiles/teleop_base_keyboard.dir/src/teleop_base_keyboard.o
/opt/ros/electric/stacks/teleop_base/src/teleop_base_keyboard.cpp: In function ‘int main(int, char**)’:
/opt/ros/electric/stacks/teleop_base/src/teleop_base_keyboard.cpp:104:85: error: cannot call constructor ‘boost::thread::thread’ directly [-fpermissive]
for a function-style cast, remove the redundant ‘::thread’ [-fpermissive]
make[3]: *** [CMakeFiles/teleop_base_keyboard.dir/src/teleop_base_keyboard.o] Error 1
make[2]: *** [CMakeFiles/teleop_base_keyboard.dir/all] Error 2
make[2]: Leaving directory `/opt/ros/electric/stacks/teleop_base/build'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/opt/ros/electric/stacks/teleop_base/build'
[ rosmake ] Output from build of package teleop_base written to:
[ rosmake ] /home/phillip/.ros/rosmake/rosmake_output-20111117- 215908/teleop_base/build_output.log
[rosmake-0] Finished <<< teleop_base [FAIL] [ 2.06 seconds ]
[ rosmake ] Halting due to failure in package teleop_base.
[ rosmake ] Waiting for other threads to complete.
[ rosmake ] Results:
[ rosmake ] Built 43 packages with 1 failures.
[ rosmake ] Summary output to directory
[ rosmake ] /home/phillip/.ros/rosmake/rosmake_output-20111117-215908
Any help as to where to start fixing this problem would be welcome. I'm not even quite sure where to look/what the errors might be in relation to. I'm new to ROS and Stage. Thank you in advance.
Originally posted by pmwalk on ROS Answers with karma: 65 on 2011-11-17
I got the same error, and looking through the output:
/opt/ros/electric/stacks/teleop_base/src/teleop_base_keyboard.cpp:104:85: error: for a function-style cast, remove the redundant ‘::thread’ [-fpermissive]
so I went into teleop_base/src/teleop_base_keyboard.cpp and removed the redundant '::thread'
It seems to work now.
Cheers!
Originally posted by Narton with karma: 83 on 2011-12-07
Post score: 5
Comment by osuairt on 2012-01-15:
You are a saint and a scholar.
Comment by pmwalk on 2011-12-15:
That seems to have been the problem, thanks!
Comment by basbaum on 2013-04-11:
Hello guys, I'm removing the '::thread' redundancy and still the problem persists - I'm using groovy now. Just checking, the line at the teleop_base_keyboard.cpp will become boost::thread t = boost::thread(boost::bind(&TBK_Node::keyboardLoop, &tbk)); correct?
