Hello,
I want to use ROS MoveIt! libraries to control a robot arm. So, I installed MoveIt! with the following command:
sudo apt-get install ros-indigo-moveit-full
Then ran:
source /opt/ros/indigo/setup.bash
Inspecting /opt/ros/indigo/include, there are now various folders with the prefix "moveit". However, if I run the command:
rospack find moveit
It prints out:
package 'moveit' not found
The same happens if I try to find ros-indigo-moveit-full.
So, why can ROS not find this package?
Originally posted by Karnivaurus on ROS Answers with karma: 133 on 2015-05-22
hi ,there,you package find is not correct, moveit is not the package name,you need to find the package in the following such as:
moveit_ros_planning
moveit_fake_controller_manager    moveit_ros_planning_interface
moveit_msgs                       moveit_ros_robot_interaction
moveit_planners_ompl              moveit_ros_visualization
moveit_ros_benchmarks             moveit_ros_warehouse
moveit_ros_benchmarks_gui         moveit_setup_assistant
moveit_ros_manipulation           moveit_simple_controller_manager
moveit_ros_move_group             moveit_visual_tools
moveit_ros_perception
Originally posted by manipulator with karma: 48 on 2015-05-22
