Hi, I tried to building a node (chapter2_tutorials) but I can't build the package
I created a workspace at home/user/ros_workspace I put the package in this folder --> chapter2_tutorials. When I try to find this package with rospack find chapter2_tutorials, it is ok.
But when I try to execture catkin_make --pkg chapter2_tutorials I have: Packages "chapter2_tutorials" not found in the workspace.
For information, I put at the end of bashrc source /home/user/ros_workspace/catkin/devel/setup.bash export ROS_PACKAGE_PATH=~ros_workspace:/opt/ros/kinetic/share
Originally posted by anthoSoben on ROS Answers with karma: 3 on 2017-05-29
Comment by spmaniato on 2017-05-29:
Don't mess with ROS_PACKAGE_PATH manually. I would remove the export line from your .bashrc. Also, it's /opt/ros/kinetic/setup.bash that you should be sourcing first and foremost. Is that in your .bashrc ?
Comment by anthoSoben on 2017-05-30:
Hi, Thanks to help me. But if I remove the export line, ROS don't find my package in my personnal workspace (ros_workspace) when I execute "rospack find chapter2_tutorials"
chapter2_tutorials is a rosbuild package so you need to use rosmake tool: rosmake chapter2_tutorials
Originally posted by ROSkinect with karma: 751 on 2017-05-30
