Hi,
I'm trying to display a simple video stream using camera1394 and image_view on Indigo and Ubuntu 14.04. I start camera1394 with this command:
rosrun camera1394 camera1394_node _guid:=b09d01008f706od:=640x480_mono8 _iso_speed:=400 _frame_rate:=30
and then I start image_view with this:
rosrun image_view image_view image:=camera/image_raw
I can see the correct stream for about 3 seconds and then the image stream freeze, but I can still use 'q' to close the image_view, so image_view is not completely crashing. The problem is, there is no error message or anything so I don't know where the problem is. If I restart image_view, it display a new image and then stop immediately.
Does anyone ran into the same problem?
Originally posted by Alex1602 on ROS Answers with karma: 23 on 2014-09-30
Comment by benabruzzo on 2014-10-14:
Similar: http://answers.ros.org/question/194741/image_proc-causes-images-to-hang/
