I am trying to stream video from my gumstix Overo to my laptop with camera1394 package. With default TCP layer, I found there are 5 to 10 seconds delay and the frame rate is just about 1 frame/sec (which is not what I set 15 frames/sec). I know I need to compress image and I will do some research on that later.
Right now, I really want to change the data transport layer from TCP to UDP because UDP is batter for tele-operation. I know that I can change the transport layer by transport hint in subscriber node. So I did that in my image_view source code "image_nodelet.cpp".
At line 118, I changed:
image_transport::TransportHints hints(transport, ros::TransportHints(), getPrivateNodeHandle());
to
image_transport::TransportHints hints(transport, ros::TransportHints().udp(), getPrivateNodeHandle());
And rosmake it again. Then I run the image_view to receive video. However I found it still utilize TCP transport layer instead of UDP. Does camera1394 support UDP transport layer?
My laptop have Ubuntu 12.04 running as a virtual machine and bridged the host network. I inspect the transport layer by wireshark in windows(host). I also doubt that if I make the right image_view package I edited because I know there is another one in /opt/ros/groovy/stacks. But I my ROS_PAKCKAGE_PATH is
/home/adrian/catkin_ws/src:/opt/ros/groovy/share:/opt/ros/groovy/stacks
So I think rosmake should make the source image_view in my workspace.
Thanks and have a good day!
Originally posted by AdrianPeng on ROS Answers with karma: 441 on 2013-02-28
Comment by Thomas on 2013-02-28:
I remember trying a couple of months ago to send images over UDP (with Electric probably) and communication was kind of unstable (sometimes the node just crashed). (I think I have been too lazy at that time to open a ticket regarding this issue, sorry!)
Comment by AdrianPeng on 2013-03-01:
I heard that UDP transport might be unstable, but I still want to try since I really concern about latency. Do you mind telling me how you send images over UDP? Did you just edit the transport hint in subscriber node? Thanks!
Comment by Thomas on 2013-03-03:
Yes this is how I did it. You should also consider trying tcpNoDelay, it may help you.
There is definitely no explicit code in camera1394 for UDP transport. Publishing the sensor_msgs/Image and sensor_msgs/CameraInfo messages is actually done in image_transport, not in the driver, itself.
Since you seem uncertain which image_view you are using, run this command:
$ rospack find image_view
I have never attempted to use UDP with camera1394, and have no idea whether it will work reliably or not. It is certainly worth trying, if that's what you need.
Originally posted by joq with karma: 25443 on 2013-02-28
Comment by AdrianPeng on 2013-02-28:
Did you use UDP with other nodes before? As far as I know, I just need to edit ros::TransportHints() in subscriber source file. Is it right?
I found the description of image_transport package description is "image_transport should always be used to subscribe to and publish images". Does image_view also use image_transport to subscribe to images? If yes, I might need to edit the source code in image_transport package.
Comment by joq on 2013-03-01:
Yes, image_view subscribes using image_transport. My impression is that UDP transport with ROS is not fully functional, but I have no personal experience using it.
Is image_transport just a library? I am not supposed to change anything in image_transport, right?
image_transport is a ROS package, which provides a library and a republish node. You can check out the source and modify it, to experiment with UDP. Making a patch that could actually be merged back into the master source tree would probably be tricky.
I have two image_transport packages, one on my gumstix Overo side and one on my laptop. Which one do I need to modify? I heard I just need to set image_transport::TransportHints to udp() in subscriber node. I am really confused, does it mean I need to modify image_transport package on my laptop?
Comment by joq on 2013-03-02:
I am not sure, maybe someone else knows the answer. You can just experiement and see what happens. You can use something like wireshark to see what packets are transmitted.
