I am following the tutorial, Using the low-level robot base controllers to drive the robot. I got a pr2 in gazebo and rosran the pr2 controller manager. When I try to roscreate-pkg drive_base_tutorial roscpp geometry_msgs this is what the terminal looks like: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WARNING: current working directory is not on ROS_PACKAGE_PATH! Please update your ROS_PACKAGE_PATH environment variable. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Created package directory /home/roger/catkin_ws/src/drive_base_tutorial Created include directory /home/roger/catkin_ws/src/drive_base_tutorial/include/drive_base_tutorial Created cpp source directory /home/roger/catkin_ws/src/drive_base_tutorial/src Created package file /home/roger/catkin_ws/src/drive_base_tutorial/Makefile Created package file /home/roger/catkin_ws/src/drive_base_tutorial/manifest.xml Created package file /home/roger/catkin_ws/src/drive_base_tutorial/CMakeLists.txt Created package file /home/roger/catkin_ws/src/drive_base_tutorial/mainpage.dox
Please edit drive_base_tutorial/manifest.xml and mainpage.dox to finish creating your package
I am using 12.04 ubuntu and groovy. export declare -x ROSLISP_PACKAGE_DIRECTORIES="" declare -x ROS_DISTRO="groovy" declare -x ROS_ETC_DIR="/opt/ros/groovy/etc/ros" declare -x ROS_PACKAGE_PATH="/opt/ros/groovy/share:/opt/ros/groovy/stacks" declare -x ROS_ROOT="/opt/ros/groovy/share/ros"
and cd is in catkin_ws/src.
Please help. I do not know how to proceed
Originally posted by Ros_newbie on ROS Answers with karma: 17 on 2014-04-08
It sounds like you're trying to follow a rosbuild tutorial and create a rosbuild package in a catkin workspace.
The PR2 packages are not catkinized in Groovy. You should instead set up a overlay rosbuild workspace for working with the PR2 controllers on Groovy.
Originally posted by ahendrix with karma: 47576 on 2014-04-08
Comment by Ros_newbie on 2014-04-09:
Thanks. It helped.
