Hello,
I am quite new to ROS and ubuntu but whatever i try i am keep getting the error so i hope someone can help me out! I need to install 2 packages:
  1. ardrone_autonomy
  2. tum_ardrone
i followed these steps for both packages:
# cd into ros root dir roscd
# clone repository git clone git://github.com/tum-vision/tum_ardrone.git tum_ardrone
# add to ros path (if required) export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:pwd/tum_ardrone
# build package (may take up to 10 minutes) rosmake tum_ardrone
even though they are both in opt/ros/hydro i can only run ardrone_autonomy whenever i try to run tum_ardrone i am getting the error.
leroy@leroy-pc:~$ env |grep ROS ROS_ROOT=/opt/ros/hydro/share/ros
ROS_PACKAGE_PATH=/opt/ros/hydro/share:/opt/ros/hydro/stacks
ROSLISP_PACKAGE_DIRECTORIES=
ROS_DISTRO=hydro
ROS_ETC_DIR=/opt/ros/hydro/etc/ros
and in my .bashrc it says : source /opt/ros/hydro/setup.bash
i am using ROS hydro and ubuntu 12.04.
thank you in advance!
Originally posted by leroyv13 on ROS Answers with karma: 1 on 2014-09-23
the first package should be available via apt-get: sudo apt-get install ros-hydro-ardrone-autonomy For the second one, why don't you use the hydro-devel branch of that repo and catkin? Also please don't install anything manually to /opt/ros. Create your own catkin workspace.
Originally posted by Chrissi with karma: 1642 on 2014-09-23
