I am using the ROS from Live USB installation Ubuntu12.04. I have already installed NITE-Bin-Dev-Linux-x86-v1.5.2.23, OpenNI-Bin-Dev-Linux-x86-v1.5.7.10, Sensor-Bin-Linux-x86-v5.1.2.1, and I aslo already run NiViewer, It can get data from ASUS Xtion Pro Live, but when I launched openni.launch, I see some problems:
core service [/rosout] found process[camera_nodelet_manager-1]: started with pid [14790] process[camera/driver-2]: started with pid [14792] process[camera/rgb/debayer-3]: started with pid [14817] process[camera/rgb/rectify_mono-4]: started with pid [14852] process[camera/rgb/rectify_color-5]: started with pid [14917] process[camera/ir/rectify_ir-6]: started with pid [14977] [ INFO] [1385713903.884362113]: Initializing nodelet with 4 worker threads. process[camera/depth/rectify_depth-7]: started with pid [15034] process[camera/depth/metric_rect-8]: started with pid [15081] process[camera/depth/metric-9]: started with pid [15114] process[camera/depth/points-10]: started with pid [15165] process[camera/register_depth_rgb-11]: started with pid [15216] process[camera/depth_registered/rectify_depth-12]: started with pid [15254] process[camera/depth_registered/metric_rect-13]: started with pid [15299] process[camera/depth_registered/metric-14]: started with pid [15332] process[camera/points_xyzrgb_depth_rgb-15]: started with pid [15414] process[camera/disparity_depth-16]: started with pid [15477] process[camera/disparity_depth_registered-17]: started with pid [15513] process[camera_base_link-18]: started with pid [15544] process[camera_base_link1-19]: started with pid [15593] process[camera_base_link2-20]: started with pid [15636] process[camera_base_link3-21]: started with pid [15685] [FATAL] [1385713907.143789132]: Service call failed! [FATAL] [1385713907.143789051]: Service call failed! [FATAL] [1385713907.143883422]: Service call failed! [FATAL] [1385713907.144111234]: Service call failed! [FATAL] [1385713907.144144695]: Service call failed! [FATAL] [1385713907.144381389]: Service call failed! [FATAL] [1385713907.144551054]: Service call failed! [FATAL] [1385713907.144673336]: Service call failed! [FATAL] [1385713907.144761994]: Service call failed! [FATAL] [1385713907.144776231]: Service call failed! [camera_nodelet_manager-1] process has died [pid 14790, exit code -11, cmd /opt/ros/groovy/lib/nodelet/nodelet manager __name:=camera_nodelet_manager __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera_nodelet_manager-1.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera_nodelet_manager-1*.log [camera/depth/metric_rect-8] process has died [pid 15081, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load depth_image_proc/convert_metric /camera_nodelet_manager --no-bond image_raw:=image_rect_raw image:=image_rect __name:=metric_rect __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth-metric_rect-8.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth-metric_rect-8*.log [camera/depth/metric-9] process has died [pid 15114, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load depth_image_proc/convert_metric /camera_nodelet_manager --no-bond __name:=metric __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth-metric-9.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth-metric-9*.log [camera/depth_registered/rectify_depth-12] process has died [pid 15254, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load image_proc/rectify /camera_nodelet_manager --no-bond image_mono:=image_raw image_rect:=image_rect_raw __name:=rectify_depth __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth_registered-rectify_depth-12.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth_registered-rectify_depth-12*.log [camera/depth/points-10] process has died [pid 15165, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load depth_image_proc/point_cloud_xyz /camera_nodelet_manager --no-bond image_rect:=image_rect_raw __name:=points __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth-points-10.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth-points-10*.log [camera/register_depth_rgb-11] process has died [pid 15216, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load depth_image_proc/register /camera_nodelet_manager --no-bond rgb/camera_info:=rgb/camera_info depth/camera_info:=depth/camera_info depth/image_rect:=depth/image_rect_raw depth_registered/image_rect:=depth_registered/image_rect_raw __name:=register_depth_rgb __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-register_depth_rgb-11.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-register_depth_rgb-11*.log [camera/depth_registered/metric-14] process has died [pid 15332, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load depth_image_proc/convert_metric /camera_nodelet_manager --no-bond __name:=metric __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth_registered-metric-14.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth_registered-metric-14*.log [camera/points_xyzrgb_depth_rgb-15] process has died [pid 15414, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load depth_image_proc/point_cloud_xyzrgb /camera_nodelet_manager --no-bond rgb/image_rect_color:=rgb/image_rect_color rgb/camera_info:=rgb/camera_info depth_registered/image_rect:=depth_registered/image_rect_raw depth_registered/points:=depth_registered/points __name:=points_xyzrgb_depth_rgb __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-points_xyzrgb_depth_rgb-15.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-points_xyzrgb_depth_rgb-15*.log [camera/disparity_depth_registered-17] process has died [pid 15513, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load depth_image_proc/disparity /camera_nodelet_manager --no-bond left/image_rect:=depth_registered/image_rect_raw right:=projector left/disparity:=depth_registered/disparity __name:=disparity_depth_registered __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-disparity_depth_registered-17.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-disparity_depth_registered-17*.log [camera/depth_registered/metric_rect-13] process has died [pid 15299, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load depth_image_proc/convert_metric /camera_nodelet_manager --no-bond image_raw:=image_rect_raw image:=image_rect __name:=metric_rect __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth_registered-metric_rect-13.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-depth_registered-metric_rect-13*.log [camera/disparity_depth-16] process has died [pid 15477, exit code 255, cmd /opt/ros/groovy/lib/nodelet/nodelet load depth_image_proc/disparity /camera_nodelet_manager --no-bond left/image_rect:=depth/image_rect_raw right:=projector left/disparity:=depth/disparity __name:=disparity_depth __log:=/home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-disparity_depth-16.log]. log file: /home/turtlebot/.ros/log/4eabffd0-58cf-11e3-bbaa-70f1a10ec189/camera-disparity_depth-16*.log
Originally posted by domikilo on ROS Answers with karma: 89 on 2013-11-28
I think you may need to get the rollback version of the openni driver. You can check my answer here.
Originally posted by Andrew.A with karma: 324 on 2013-12-22
