hasitha@hasitha-HP-ProBook-4520s:~$ rosmake rgbdslam_freiburg [ rosmake ] rosmake starting... [ rosmake ] Packages requested are: ['rgbdslam_freiburg'] [ rosmake ] Logging to directory /home/hasitha/.ros/rosmake/rosmake_output-20131028-235835 [ rosmake ] Expanded args ['rgbdslam_freiburg'] to: ['rgbdslam'] [rosmake-0] Starting >>> roslang [ make ] [rosmake-1] Starting >>> geometry_msgs [ make ] [rosmake-2] Starting >>> opencv2 [ make ] [rosmake-3] Starting >>> bullet [ make ] [rosmake-0] Finished <<< roslang No Makefile in package roslang [rosmake-2] Finished <<< opencv2 ROS_NOBUILD in package opencv2 [rosmake-0] Starting >>> rospy [ make ] [rosmake-2] Starting >>> roscpp [ make ] [rosmake-1] Finished <<< geometry_msgs No Makefile in package geometry_msgs [rosmake-1] Starting >>> sensor_msgs [ make ] [rosmake-0] Finished <<< rospy No Makefile in package rospy [rosmake-3] Finished <<< bullet ROS_NOBUILD in package bullet [rosmake-0] Starting >>> rosconsole [ make ] [rosmake-3] Starting >>> angles [ make ] [rosmake-3] Finished <<< angles ROS_NOBUILD in package angles [rosmake-3] Starting >>> rostest [ make ] [rosmake-2] Finished <<< roscpp No Makefile in package roscpp [rosmake-2] Starting >>> roswtf [ make ] [rosmake-0] Finished <<< rosconsole No Makefile in package rosconsole [rosmake-1] Finished <<< sensor_msgs No Makefile in package sensor_msgs [rosmake-0] Starting >>> message_filters [ make ] [rosmake-1] Starting >>> image_geometry [ make ] [rosmake-3] Finished <<< rostest No Makefile in package rostest [rosmake-1] Finished <<< image_geometry ROS_NOBUILD in package image_geometry [rosmake-3] Starting >>> std_msgs [ make ] [rosmake-2] Finished <<< roswtf No Makefile in package roswtf [rosmake-1] Starting >>> rosbag [ make ] [rosmake-0] Finished <<< message_filters No Makefile in package message_filters [rosmake-2] Starting >>> rosbuild [ make ] [rosmake-0] Starting >>> tf [ make ] [rosmake-0] Finished <<< tf ROS_NOBUILD in package tf [rosmake-2] Finished <<< rosbuild No Makefile in package rosbuild [rosmake-1] Finished <<< rosbag No Makefile in package rosbag [rosmake-3] Finished <<< std_msgs No Makefile in package std_msgs [rosmake-0] Starting >>> roslib [ make ] [rosmake-1] Starting >>> pcl [ make ] [rosmake-2] Starting >>> smclib [ make ] [rosmake-3] Starting >>> rosservice [ make ] [rosmake-0] Finished <<< roslib No Makefile in package roslib [rosmake-0] Starting >>> pluginlib [ make ] [rosmake-2] Finished <<< smclib ROS_NOBUILD in package smclib [rosmake-3] Finished <<< rosservice No Makefile in package rosservice [rosmake-2] Starting >>> bond [ make ] [rosmake-3] Starting >>> dynamic_reconfigure [ make ] [rosmake-1] Finished <<< pcl ROS_NOBUILD in package pcl No Makefile in package pcl [rosmake-0] Finished <<< pluginlib ROS_NOBUILD in package pluginlib [rosmake-0] Starting >>> common_rosdeps [ make ] [rosmake-2] Finished <<< bond ROS_NOBUILD in package bond [rosmake-2] Starting >>> bondcpp [ make ] [rosmake-1] Starting >>> cv_bridge [ make ] [rosmake-1] Finished <<< cv_bridge ROS_NOBUILD in package cv_bridge [rosmake-2] Finished <<< bondcpp ROS_NOBUILD in package bondcpp [rosmake-2] Starting >>> nodelet [ make ] [rosmake-1] Starting >>> visualization_msgs [ make ] [rosmake-0] Finished <<< common_rosdeps ROS_NOBUILD in package common_rosdeps [rosmake-0] Starting >>> octomap_ros [ make ] [rosmake-3] Finished <<< dynamic_reconfigure ROS_NOBUILD in package dynamic_reconfigure [rosmake-3] Starting >>> nav_msgs [ make ] [rosmake-2] Finished <<< nodelet ROS_NOBUILD in package nodelet [rosmake-2] Starting >>> nodelet_topic_tools [ make ] [rosmake-1] Finished <<< visualization_msgs No Makefile in package visualization_msgs [rosmake-1] Starting >>> actionlib_msgs [ make ] [rosmake-0] Finished <<< octomap_ros ROS_NOBUILD in package octomap_ros [rosmake-3] Finished <<< nav_msgs No Makefile in package nav_msgs [rosmake-0] Starting >>> trajectory_msgs [ make ] [rosmake-3] Starting >>> std_srvs [ make ] [rosmake-2] Finished <<< nodelet_topic_tools ROS_NOBUILD in package nodelet_topic_tools [rosmake-2] Starting >>> pcl_ros [ make ] [rosmake-1] Finished <<< actionlib_msgs No Makefile in package actionlib_msgs [rosmake-2] Finished <<< pcl_ros ROS_NOBUILD in package pcl_ros [rosmake-0] Finished <<< trajectory_msgs No Makefile in package trajectory_msgs [rosmake-3] Finished <<< std_srvs No Makefile in package std_srvs [rosmake-2] Starting >>> flann [ make ] [rosmake-0] Starting >>> mk [ make ] [rosmake-3] Starting >>> orocos_kdl [ make ] [rosmake-1] Starting >>> arm_navigation_msgs [ make ] [rosmake-2] Finished <<< flann ROS_NOBUILD in package flann [rosmake-2] Starting >>> opencv_tests [ make ] [rosmake-3] Finished <<< orocos_kdl ROS_NOBUILD in package orocos_kdl [rosmake-0] Finished <<< mk No Makefile in package mk [rosmake-2] Finished <<< opencv_tests ROS_NOBUILD in package opencv_tests [rosmake-1] Finished <<< arm_navigation_msgs ROS_NOBUILD in package arm_navigation_msgs [rosmake-1] Starting >>> octomap_server [ make ] [rosmake-3] Starting >>> python_orocos_kdl [ make ] [rosmake-1] Finished <<< octomap_server ROS_NOBUILD in package octomap_server [rosmake-1] Starting >>> rgbdslam [ make ] [rosmake-3] Finished <<< python_orocos_kdl ROS_NOBUILD in package python_orocos_kdl [rosmake-3] Starting >>> kdl [ make ] [rosmake-3] Finished <<< kdl ROS_NOBUILD in package kdl No Makefile in package kdl [rosmake-3] Starting >>> eigen_conversions [ make ] [rosmake-3] Finished <<< eigen_conversions ROS_NOBUILD in package eigen_conversions [rosmake-3] Starting >>> tf_conversions [ make ] [rosmake-3] Finished <<< tf_conversions ROS_NOBUILD in package tf_conversions [rosmake-3] Starting >>> cv_markers [ make ] [rosmake-3] Finished <<< cv_markers ROS_NOBUILD in package cv_markers [ rosmake ] All 2 linesrgbdslam: 0.0 sec ] [ 1 Active 47/48 Complete ] {------------------------------------------------------------------------------- mkdir: cannot create directory `build': Permission denied
[ rosmake ] Output from build of package rgbdslam written to:
[ rosmake ] /home/hasitha/.ros/rosmake/rosmake_output-20131028-235835/rgbdslam/build_output.log
[rosmake-1] Finished <<< rgbdslam [FAIL] [ 0.07 seconds ]
[ rosmake ] Halting due to failure in package rgbdslam.
[ rosmake ] Waiting for other threads to complete.
[ rosmake ] Results:
[ rosmake ] Built 48 packages with 1 failures.
[ rosmake ] Summary output to directory
Originally posted by Hasitha on ROS Answers with karma: 19 on 2013-10-28
