Hi, all. I am trying to get joints data from the codes of http://www.ros.org/wiki/openni/Contests/ROS%203D/Skeleton%20Tracker%20Teleoperation%20Package%20for%20Mobile%20Robot . I just have kinect but donot have the pi robot. After rosmake pi_tracker, the log shows
[ rosmake ] Packages requested are: ['pi_tracker']
[ rosmake ] Logging to directory/home/nutan/.ros/rosmake/rosmake_output-20110301-134928 [ rosmake ] Expanded args ['pi_tracker'] to: ['pi_tracker']
[ rosmake ] Checking rosdeps compliance for packages pi_tracker. This may take a few seconds. Failed to find stack for package [pi_lib] Failed to load rosdep.yaml for package [pi_lib]:Cannot locate installation of package pi_lib: [rospack] couldn't find package [pi_lib]. ROS_ROOT[/opt/ros/cturtle/ros] ROS_PACKAGE_PATH[/home/nutan/pi:/home/nutan/kinect_demos/motion_planning_common:/home/nutan/kinect_demos/geometry_experimental:/home/nutan/kinect_demos/ros-geometry:/home/nutan/kinect_demos/mit-ros-pkg-experimental:/home/nutan/kinect_demos/mit-ros-pkg:/home/nutan/kinect_demos/point_cloud_perception:/home/nutan/kinect_demos/perception_pcl:/home/nutan/kinect_demos/perception_pcl_addons:/home/nutan/kinect_demos/trunk_cturtle:/home/nutan/kinect_demos/ros_experimental:/home/nutan/kinect_demos/ni:/opt/ros/cturtle/stacks] [ rosmake ] rosdep check passed all system dependencies in packages
[rosmake-0] Starting >>> pi_tracker [ make ]
[rosmake-1] Starting >>> roslang [ make ]
[ rosmake ] All 22 lines {------------------------------------------------------------------------------- mkdir -p bin cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=rospack find rosbuild/rostoolchain.cmake .. [rosbuild] Building package pi_tracker Failed to invoke /opt/ros/cturtle/ros/bin/rospack deps-manifests pi_tracker [rospack] couldn't find dependency [pi_lib] of [pi_tracker] [rospack] missing dependency [rosmake-1] Finished <<< roslang ROS_NOBUILD in package roslang No Makefile in package roslang
CMake Error at /opt/ros/cturtle/ros/core/rosbuild/public.cmake:113 (message):
Failed to invoke rospack to get compile flags for package 'pi_tracker'.
Look above for errors from rospack itself.  Aborting.  Please fix the
broken dependency!
Call Stack (most recent call first): /opt/ros/cturtle/ros/core/rosbuild/public.cmake:178 (rosbuild_invoke_rospack) CMakeLists.txt:12 (rosbuild_init)
[ rosmake ] Output from build of package pi_tracker written to: [ rosmake ] /home/nutan/.ros/rosmake/rosmake_output-20110301-134928/pi_tracker/build_output.log [rosmake-0] Finished <<< pi_tracker [FAIL] [ 0.22 seconds ]
[rosmake-2] Starting >>> roslib [ make ]
[rosmake-2] Finished <<< roslib ROS_NOBUILD in package roslib
[rosmake-3] Starting >>> xmlrpcpp [ make ]
[rosmake-3] Finished <<< xmlrpcpp ROS_NOBUILD in package xmlrpcpp
[ rosmake ] Halting due to failure in package pi_tracker. [ rosmake ] Waiting for other threads to complete. [ rosmake ] Results:
[ rosmake ] Built 6 packages with 1 failures.
[ rosmake ] Summary output to directory
=========================================================== Also, i type in roslaunch pi_tracker skeleton.launch, it appears
... logging to /home/nutan/.ros/log/a41a5ae0-43c7-11e0-ae7f-00e081b5d370/roslaunch-nutan-desktop-10909.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://nutan-desktop:49833/
SUMMARY
PARAMETERS
  • /use_sim_time
  • /skeleton_tracker/fixed_frame
  • /skeleton_tracker/holonomic
  • /skeleton_tracker/skel_to_joint_map/right_shoulder
  • /skeleton_tracker/tracking_rate
  • /skeleton_tracker/skel_to_joint_map/right_hip
  • /skeleton_tracker/command_rate
  • /skeleton_tracker/skel_to_joint_map/left_foot
  • /skeleton_tracker/skel_to_joint_map/left_elbow
  • /skeleton_tracker/skel_to_joint_map/right_foot
  • /skeleton_tracker/use_real_robot
  • /skeleton_tracker/skel_to_joint_map/right_knee
  • /skeleton_tracker/skel_to_joint_map/left_shoulder
  • /skeleton_tracker/scale_drive_speed
  • /skeleton_tracker/base_controller_rate
  • /skeleton_tracker/skel_to_joint_map/left_knee
  • /skeleton_tracker/base_control_side
  • /robot_description
  • /skeleton_tracker/skel_to_joint_map/head
  • /skeleton_tracker/max_rotation_speed
  • /skeleton_tracker/skel_to_joint_map/torso
  • /skeleton_tracker/skel_to_joint_map/right_hand
  • /skeleton_tracker/skel_to_joint_map/right_elbow
  • /skeleton_tracker/default_joint_speed
  • /skeleton_tracker/max_drive_speed
  • /skeleton_tracker/scale_rotation_speed
  • /robot_state_publisher/publish_frequency
  • /skeleton_tracker/reverse_rotation
  • /skeleton_tracker/skel_to_joint_map/neck
  • /skeleton_tracker/skel_to_joint_map/left_hand
  • /skeleton_tracker/joint_controller_rate
  • /skeleton_tracker/skel_to_joint_map/left_hip
NODES / robot_state_publisher (robot_state_publisher/state_publisher) kinect_base_link (tf/static_transform_publisher) kinect_base_link1 (tf/static_transform_publisher) kinect_base_link2 (tf/static_transform_publisher) kinect_base_link3 (tf/static_transform_publisher) skeleton_tracker (pi_tracker/skeleton_tracker) base_world_broadcaster (tf/static_transform_publisher)
starting new master (master configured for auto start) process[master]: started with pid [10926] ROS_MASTER_URI=http://nutan-desktop:11311/
setting /run_id to a41a5ae0-43c7-11e0-ae7f-00e081b5d370 process[rosout-1]: started with pid [10939] started core service [/rosout] process[robot_state_publisher-2]: started with pid [10952] process[kinect_base_link-3]: started with pid [10953] process[kinect_base_link1-4]: started with pid [10961] process[kinect_base_link2-5]: started with pid [10979] process[kinect_base_link3-6]: started with pid [10993] process[skeleton_tracker-7]: started with pid [11003] process[base_world_broadcaster-8]: started with pid [11015] [skeleton_tracker-7] process has died [pid 11003, exit code -11]. log files: /home/nutan/.ros/log/a41a5ae0-43c7-11e0-ae7f-00e081b5d370/skeleton_tracker-7*.log
I just need the data of the joints from kinect. If you have any suggestion, it is appreciated in advance.
Originally posted by Nutan on ROS Answers with karma: 96 on 2011-02-28
Sorry about that. I failed to include the dependency on the pi_lib package on the Contest wiki page. (I have since corrected that.) So please get the pi_lib package using:
svn checkout http://pi-robot-ros-pkg.googlecode.com/svn/trunk/pi_lib
then try rosmake on pi_tracker again.
--patrick
Originally posted by Pi Robot with karma: 4046 on 2011-03-01
Comment by Pi Robot on 2011-03-02:
OK, I have fixed the hard coded path. It is now defined in the skeleton.launch file and the default should work without modification.
Ah yes! Good catch. That source file is from Taylor Veltrop's original skeleton tracker package and even though I believe he fixed the hard coded path in his package, I forgot to do the same. So I'll get to it now. Thanks for the reminder and sorry it tripped you up.
Comment by Nutan on 2011-03-02:
Thank you very much. Kinect is no problem. The reason is SAMPLE_XML_PATH "/home/patrick/ni/ni/openni/lib/SamplesConfig.xml" in KinectController.cpp. It works after changing the path as my computer.
The only way I can get that error is if I don't have the Kinect hooked up (power and USB) when I run 'roslaunch pi_tracker skeleton.launch'. So a good test of your Kinect (if you haven't already done it) is to try 'roslaunch openni_camera openni_kinect.launch' and then, assuming no errors, in a separate terminal run something like 'rosrun nite Sample-PointViewer'.
Comment by Nutan on 2011-03-01:
Thank you very much. Rosmake is successful now. But roslaunch pi_tracker skeleton.launch is still failed.Is it because that I do not have robot? process[robot_state_publisher-2]: started with pid [13510] process[kinect_base_link-3]: started with pid [13511] process[kinect_base_link1-4]: started with pid [13512] process[kinect_base_link2-5]: started with pid [13532] process[kinect_base_link3-6]: started with pid [13544] process[skeleton_tracker-7]: started with pid [13557] process[base_world_broadcaster-8]: started with pid [13573] [skeleton_tracker-7] process has died [pid 13557, exit code -11]. log files: /home/nutan/.ros/log/09472306-4474-11e0-b8f6-00e081b5d370/skeleton_tracker-7*.log
