When trying to visualize the simplest model in the urdf tutorial "Building a Visual Robot Model with URDF from Scratch" using the following command in Groovy:
roslaunch urdf_tutorial display.launch model:=01-myfirst.urdf
I get a blank(dark grey) display window named "urdf.vcg" instead of the usual Rviz window. However, running
rosrun rviz rviz
Works as expected. Is it a problem with my installation or does the tutorial need to be updated?
JML
Originally posted by JML on ROS Answers with karma: 26 on 2013-05-22
3 Answers 3
This is similar to this question
A recent patch by Shaun Edwards adds a Groovy compatible config file.
Originally posted by David Lu with karma: 10932 on 2013-05-22
Works, thanks (and thanks Shaun)!
JML
Originally posted by JML with karma: 26 on 2013-05-22
I just removed the line "" from the display.launch file and manually added RobotModel to rviz. Everytime I reload the display.launch file, I just uncheck and check the box to the right of RobotModel on rviz to reload the updated urdf model.
