I am learning ROS tutorial (Building a Visual Robot Model with URDF from Scratch) and when I rum this command
roslaunch urdf_tutorial display.launch model:=01-myfirst.urdf
I got following result.
Originally posted by wafeeq on ROS Answers with karma: 3 on 2013-09-20
Comment by wafeeq on 2013-09-20:
ERROR: cannot launch node of type [robot_state_publisher/state_publisher]: robot_state_publisher ROS path [0]=/opt/ros/hydro/share/ros ROS path [1]=/home/wafeeq/catkin_ws/src/pr2_common ROS path [2]=/opt/ros/hydro/share ROS path [3]=/opt/ros/hydro/share ROS path [4]=/opt/ros/hydro/stacks
I have also installed robot_state_publisher but it could not find state_publisher a node of it.
ERROR: cannot launch node of type [robot_state_publisher/state_publisher]: can't locate node [state_publisher] in package [robot_state_publisher]
Comment by wafeeq on 2013-09-21:
Can anybody help me please?
Comment by cstew on 2014-04-28:
I'm trying to incorporate gazebo_ros_control plugin in my own urdf and starting by just putting a controller on a single joint. I keep getting the same error saying "cannont launch node of this type..." ros-hydro-robot-state-publisher installed. Did you find a solution to this?
Do you have ros-hydro-robot-state-publisher installed?
If not, try
sudo apt-get install ros-hydro-robot-state-publisher
Originally posted by mortonjt with karma: 217 on 2013-09-21
Post score: 9
Comment by wafeeq on 2013-09-22:
wow great it worked. But I had also installed robot_state_publisher manually but it did not work. thanks
Comment by sujeet on 2018-07-23:
When I tried to run the commanded, it gave me the following error. E: Unable to locate package ros-hydro-robot-state-publisher Is there a way to fix this issue?
Comment by wmbolle on 2020-04-12:
You probably have to adapt to your version of ROS. For me, it is ros-melodic-robot-state-publisher. You should be able to find the right package name via apt-cache search robot-state-publisher.
