There is no verification afaik, besides looking at the topics.
You can try to connect to the server via a simple tool and test if something replies:
rosrun actionlib axclient.py /my_action
Originally posted by dornhege with karma: 31395 on 2013-04-09
Comment by Shanker on 2013-04-09:
What type of topic should '/my_action' be? Since Rviz sent a goal to the topic /move_base_simple/goal which is of type 'geometry_msgs/PoseStamped', I tried that. However I get an error similar to 'assert('Goal' in topic type)', which is quite self evident.
I then tried the topic '/move_base/goal' which is of type '/move_base_msgs/MoveBaseActionGoal'. I then do get the GUI, however there is a red error on the bottom of the GUI box which says 'No Goal and Disconnected from server'. I've tried to fill the fields in but it makes no difference.
Comment by dornhege on 2013-04-10:
I think it's just move_base. The /move_base_simple is not using actionlib.
Comment by Shanker on 2013-04-10:
Right. I have added an edit to my question. It relates to how to start the move_base action server. I would appreciate if you could look at it. Thanks..
In the actionclient GUI, is 'Disconnected from server' the default/start statement?
move_base should be the node to run "everything". It might not come up properly if misconfigured, but there should be warnings. Thus, when rviz works usually the actionclient also works, although it's not 100% guaranteed as rviz uses another mechanism.
Comment by Shanker on 2013-04-14:
That's what I thought as well. Rviz works perfectly, yet the autoclient does not. Also, the simple action client does not work as well. It waits indefinitely as I mentioned at waitForServer().
Comment by dornhege on 2013-04-14:
/move_base should be the action to connect to. There should be actionlib related topics in the move_base node. If not, something is wrong.
Comment by Shanker on 2013-04-19:
I was using multiple clients and servers and connecting to the wrong one. Your answer of using the GUI client is the right one.
