I'm working on Ubuntu 11.10 with ROS Furete I want to install tabletop_objects_detector package to use it with household_objects_database ,so I wrote this command in the terminal : sudo apt-get install ros-fuerte-pr2-object-manipulation unfortunately I got this error : E: Unable to locate package ros-fuerte-pr2-object-manipulation What should I do ?
Originally posted by RiskTeam on ROS Answers with karma: 238 on 2013-03-05
Make sure you have setup your apt sources correctly.
The packages is present and available from the repository.
Originally posted by tfoote with karma: 58457 on 2013-03-05
