Hello!
When i'm going to run rviz, it sometimes breaks showing this error:
The program 'rviz' received an X Window System error. This probably reflects a bug in the program. The error was 'BadDrawable (invalid Pixmap or Window parameter)'. (Details: serial 22 error_code 9 request_code 137 minor_code 3) (Note to programmers: normally, X errors are reported asynchronously; that is, you will receive the error a while after causing it. To debug your program, run it with the --sync command line option to change this behavior. You can then get a meaningful backtrace from your debugger if you break on the gdk_x_error() function.) [rviz-1] process has died [pid 2540, exit code 1]. log files: /home/alonso/.ros/log/72e5fea2-8403-11e1-ad7f-0018de214925/rviz-1*.log
I've got Ubuntu 10.10 and i don't know why sometimes breaks and the other times no :S.
I read this post: http://answers.ros.org/question/2775/rviz-crashing-at-startup-with-baddrawable
But it didn't solve it... I also recompiled e reinstalled rviz but either...
Any idea to solve it?
Thanks!
Originally posted by alonsosjumper on ROS Answers with karma: 9 on 2012-04-11
