I followed the instruction steps on http://ros.org/wiki/openni_kinect with:
sudo apt-get install ros-electric-openni-kinect
hg clone https://kforge.ros.org/openni/drivers openni-drivers
cd openni-drivers
make
sudo make install
All instructions works fine till then "sudo make install" I get an error which looks like this:
sudo make install
cd openni && make
make[1]: Betrete Verzeichnis '/home/user/ros_workspace/openni-drivers/openni'
cd build/openni/Platform/Linux/CreateRedist && bash RedistMaker && cd -
* PrimeSense OpenNI Redist *
* 2012-04-03 17:45:18 *
Target: Linux-x86
Version: 1.5.2.23
Num of compile jobs: 2
* Building OpenNI...
../../../../../Source/Utils/niLicense/niLicense.cpp: In Funktion »int main(int, char**)«:
../../../../../Source/Utils/niLicense/niLicense.cpp:122:108: Warnung: Format »%lu« erwartet Argumenttyp »long unsigned int«, aber Argument 2 hat Typ »unsigned int« [-Wformat]
../../../../../Source/Utils/niLicense/niLicense.cpp:129:97: Warnung: Format »%lu« erwartet Argumenttyp »long unsigned int«, aber Argument 2 hat Typ »unsigned int« [-Wformat]
* Creating Doxygen...
warning: ignoring unsupported tag `INLINE_SIMPLE_STRUCTS =' at line 304, file Doxyfile
warning: ignoring unsupported tag `CITE_BIB_FILES =' at line 579, file Doxyfile
warning: ignoring unsupported tag `MATHJAX_EXTENSIONS =' at line 1202, file Doxyfile
warning: ignoring unsupported tag `LATEX_BIB_STYLE =' at line 1321, file Doxyfile
warning: ignoring unsupported tag `INTERACTIVE_SVG =' at line 1734, file Doxyfile
When enabling GENERATE_HTMLHELP the tree view (GENERATE_TREEVIEW) should be disabled. I'll do it for you.
sh: C:\Program Files\HTML Help Workshop\hhc.exe: not found
error: failed to run html help compiler on index.hhp
* Creating Redist Dir...
* Copying files to redist dir...
Samples: ['NiRecordSynthetic', 'NiSimpleSkeleton', 'NiSampleModule', 'NiCRead', 'NiUserSelection', 'NiSimpleCreate', 'NiAudioSample', 'NiSimpleViewer', 'NiHandTracker', 'NiSimpleRead', 'NiConvertXToONI', 'SimpleViewer.java', 'NiUserTracker', 'SimpleRead.java', 'UserTracker.java', 'NiViewer', 'NiBackRecorder']
* Removing Read Only Attributes...
* Fixing Files...
* Creating Makefile...
* Copying install script...
* Building Samples in release configuration......
* Building Samples in debug configuration......
* Creating tar......
* Redist OpenNi Ended. !!
touch installed
make[1]: Verlasse Verzeichnis '/home/jerome/ros_workspace/openni-drivers/openni'
sudo mkdir -p /usr/include/openni \
/etc/openni \
/usr/share/openni/doc \
/usr/share/openni/samples \
/usr/lib/pkgconfig
sudo cp -f ./openni/build/openni/Platform/Linux/Redist/OpenNI-Bin-Dev-Linux-x86-v1.5.2.23/Samples/Config/* /etc/openni/
sudo cp -f ./openni/build/openni/Platform/Linux/Redist/OpenNI-Bin-Dev-Linux-x86-v1.5.2.23/Lib/*.so /usr/lib/
sudo cp -r ./openni/build/openni/Platform/Linux/Redist/OpenNI-Bin-Dev-Linux-x86-v1.5.2.23/Include/* /usr/include/openni/
sudo cp -f ./openni/build/openni/Platform/Linux/Redist/OpenNI-Bin-Dev-Linux-x86-v1.5.2.23/Bin/* /usr/bin/
sudo cp -f ./openni/build/openni/Platform/Linux/Redist/OpenNI-Bin-Dev-Linux-x86-v1.5.2.23/Documentation/html/* /usr/share/openni/doc/
sudo cp -f ./openni/build/openni/Platform/Linux/Redist/OpenNI-Bin-Dev-Linux-x86-v1.5.2.23/Samples/Bin/x86-Release/Sample-* /usr/share/openni/samples/
sudo cp -f ./openni/build/openni/Platform/Linux/Redist/OpenNI-Bin-Dev-Linux-x86-v1.5.2.23/Samples/Bin/x86-Release/NiViewer /usr/share/openni/samples/
sudo sed s/__VERSION__/1.5.2.23~oneiric/ ./CONTROL/openni.pc > /usr/lib/pkgconfig/openni-dev.pc
sudo /bin/bash ./CONTROL/openni_postinst configure
./CONTROL/openni_postinst: Zeile 21: 21984 Ungültiger Maschinenbefehl /usr/bin/niReg -r /usr/lib/libnimCodecs.so /etc/openni
make: *** [install_openni] ERROR 132
user@userPC:~/ros_workspace/openni-drivers$
This error occurs in the makefile-directory (~/openni-drivers/CONTROL/openni_postinst):
/usr/bin/niReg -r /usr/lib/libnimMockNodes.so /etc/openni
/usr/bin/niReg -r /usr/lib/libnimRecorder.so /etc/openni
It's a basic installation error, but I dont know where to look at to solve this instruction error.
Or could I comment this line of codes?
Best regards from Germany
Originally posted by GermanUser on ROS Answers with karma: 125 on 2012-04-03
Comment by GermanUser on 2012-04-03:
This error already exists here but there was no answer: http://answers.ros.org/question/12174/problem-installing-openni-on-ubuntu-1004
