Cant make opennni distribution:groovy
↓error massage make[1]: Entering directory `/home/viki/drivers/openni' cd build/openni/Platform/Linux/CreateRedist && bash RedistMaker && cd -
  • PrimeSense OpenNI Redist *
  • 2013-06-30 21:22:15       *
Target: Linux-x86 Version: 1.5.4.0 Num of compile jobs: 2
  • Building OpenNI... ../../../../Source/OpenNI/XnPlayerImpl.cpp: In constructor ‘xn::PlayerImpl::PlayerImpl()’: ../../../../Source/OpenNI/XnPlayerImpl.cpp:71:33: warning: converting to non-pointer type ‘int’ from NULL [-Wconversion-null] ../../../../Source/OpenNI/XnRecorderImpl.cpp: In constructor ‘xn::RecorderImpl::RecorderImpl()’: ../../../../Source/OpenNI/XnRecorderImpl.cpp:51:18: warning: converting to non-pointer type ‘int’ from NULL [-Wconversion-null] ../../../../../Samples/NiViewer/Device.cpp: In function ‘XnStatus openDeviceFromXmlWithChoice(const char*, xn::EnumerationErrors&)’: ../../../../../Samples/NiViewer/Device.cpp:252:22: warning: ignoring return value of ‘int scanf(const char*, ...)’, declared with attribute warn_unused_result [-Wunused-result] /bin/sh: 1: javac: not found make[3]: *** [../../../Bin/x86-Release/org.OpenNI.jar] Error 127 make[2]: *** [Wrappers/OpenNI.java] Error 2 make[2]: *** Waiting for unfinished jobs.... failed to execute: make -j2 -C /home/viki/drivers/openni/build/openni/Platform/Linux/CreateRedist/../Build > /home/viki/drivers/openni/build/openni/Platform/Linux/CreateRedist/Output/BuildOpenNI.txt Building Failed! make[1]: *** [installed] Error 1 make[1]: Leaving directory `/home/viki/drivers/openni' make: *** [openni_lib] Error 2
Originally posted by Ichiro suzuki on ROS Answers with karma: 1 on 2013-06-30
It looks like you are missing javac which is usually in standard JDKs.
Originally posted by tfoote with karma: 58457 on 2013-08-12
