I am trying to create a Python client for the service planning_scene_validity_server/get_trajectory_validity.
When I call the service I seem to only get back the default JointTrajectoryValidityResponse object. The returned object prints as:
Validity response error_code:
  val: 0
trajectory_error_codes: []
contacts: []
ROS Version: Electric
OS: Ubuntu 11.10
My code is below:
import sys;
import roslib; roslib.load_manifest('fast_planning');
import rospy
from arm_navigation_msgs.srv import GetJointTrajectoryValidity
from arm_navigation_msgs.srv import GetJointTrajectoryValidityRequest
from arm_navigation_msgs.srv import GetJointTrajectoryValidityResponse
from arm_navigation_msgs.srv import SetPlanningSceneDiff
from trajectory_msgs.msg import JointTrajectory
from trajectory_msgs.msg import JointTrajectoryPoint
import numpy
SET_PLANNING_SCENE_DIFF_NAME = "/environment_server/set_planning_scene_diff";
#arg tray, type = trajectory_msgs/JointTrajectory
def get_full_trajectory_validity(traj):
    try:
        rospy.init_node("get_collision_free_ik_py");
        print "waiting for service"
        rospy.wait_for_service("planning_scene_validity_server/get_trajectory_validity");
        print "found service"
        validity_client = rospy.ServiceProxy("planning_scene_validity_server/get_trajectory_validity", GetJointTrajectoryValidity);
        set_planning_scene_diff_client = rospy.ServiceProxy(SET_PLANNING_SCENE_DIFF_NAME, SetPlanningSceneDiff);
        robot_state = set_planning_scene_diff_client().planning_scene.robot_state;
        validity_request = GetJointTrajectoryValidityRequest();
        #validity_request.robot_state = robot_state;
        #All sample points in the trajectory will be checked
        validity_request.check_full_trajectory = True;
        validity_request.check_collisions = True;
        validity_request.check_joint_limits
        validity_request.trajectory = traj
        validity_response = validity_client(validity_request);
        print "Validity response", validity_response
        print "Error code val", validity_response.error_code.val
        print "Error codes", validity_response.trajectory_error_codes
    except rospy.ROSInterruptException:
        print "program interrupted before completion"
if __name__ == '__main__':
    traj = JointTrajectory();
    traj.joint_names.append("r_shoulder_pan_joint")
    sample_points = [];
    start = 3;
    end = -3;
    for i in range(0, 100):
        point = JointTrajectoryPoint();
        point.positions.append(start+(i*.01*(start-end)));
        sample_points.append(point);
    traj.points = sample_points;
Originally posted by robbie on ROS Answers with karma: 20 on 2012-01-13
The service function is definitely empty right now. I'll release a fix soon, but in the mean time if you need trajectory validity you'll have to use C++, as described in this tutorial:
getting trajectory validity
Originally posted by egiljones with karma: 2031 on 2012-01-13
