I am migrating from the turtlebot3 to my own vehicle with nav2. The robot does not move after a Nav2 goal is given, and i suspect the trajectory is not feasible.
I have the x-Axis pointing in driving direction and setting a 2D Pose Estimate does align the robot in driving direction, when i apply a Nav2 Goal i get a trajectory but the arrows within are orthogonal to the driving direction, i guess this makes it unfeasible for the robot to follow it.
Where can i change these settings? Or am i wrong about the transformations? Is x in driving direction a convention for nav2?
Edit: The orientation comes from the map frame, however, i still see no movement of the robot, it might be more related to the settings i guess
[component_container_isolated-6] [WARN] [1724930152.477387555] [BehaviorTreeEngine]: Behavior Tree tick rate 100.00 was exceeded!
[rviz2-5] [INFO] [1724930152.492994788] [rviz2]: Message Filter dropping message: frame 'odom' at time 1724930146.433 for reason 'discarding message because the queue is full'
[rviz2-5] [INFO] [1724930153.077604571] [rviz2]: Message Filter dropping message: frame 'odom' at time 1724930147.061 for reason 'discarding message because the queue is full'
[rviz2-5] [INFO] [1724930153.679257406] [rviz2]: Message Filter dropping message: frame 'odom' at time 1724930147.634 for reason 'discarding message because the queue is full'
[rviz2-5] [INFO] [1724930154.289066914] [rviz2]: Message Filter dropping message: frame 'odom' at time 1724930148.234 for reason 'discarding message because the queue is full'
[rviz2-5] [INFO] [1724930154.889846097] [rviz2]: Message Filter dropping message: frame 'odom' at time 1724930148.834 for reason 'discarding message because the queue is full'
[rviz2-5] [INFO] [1724930155.471113928] [rviz2]: Message Filter dropping message: frame 'odom' at time 1724930149.433 for reason 'discarding message because the queue is full'
[rviz2-5] [INFO] [1724930156.065253570] [rviz2]: Message Filter dropping message: frame 'odom' at time 1724930150.034 for reason 'discarding message because the queue is full'
[component_container_isolated-6] [WARN] [1724930156.330377415] [BehaviorTreeEngine]: Behavior Tree tick rate 100.00 was exceeded!
[rviz2-5] [INFO] [1724930156.642716022] [rviz2]: Message Filter dropping message: frame 'odom' at time 1724930150.634 for reason 'discarding message because the queue is full'
[component_container_isolated-6] [WARN] [1724930156.990832274] [BehaviorTreeEngine]: Behavior Tree tick rate 100.00 was exceeded!
[component_container_isolated-6] [WARN] [1724930157.098119951] [behavior_server]: Exceeded time allowance before reaching the Spin goal - Exiting Spin
[component_container_isolated-6] [WARN] [1724930157.098221214] [behavior_server]: spin failed
[component_container_isolated-6] [WARN] [1724930157.098241042] [behavior_server]: [spin] [ActionServer] Aborting handle.
[component_container_isolated-6] [INFO] [1724930157.117086711] [behavior_server]: Running wait
[rviz2-5] [INFO] [1724930157.263304383] [rviz2]: Message Filter dropping message: frame 'odom' at
