I want to create a scenario where I have one package ("the_exec") that defines an interface the_exec::AEIF and depending on a configuration file loads some plugins.
When I create just the interface and a simple main this line doesn't work:
int main(int argc, char** argv)
pluginlib::ClassLoader<the_exec::AEIF> poly_loader("the_exec", "the_exec::AEIF");
and gives me:
terminate called after throwing an instance of 'pluginlib::LibraryLoadException' what(): rospack could not find the the_exec package containing the_exec::AEIF
This happens even when I do not try to load any plugins.
However, when I define one simple package that contains plugins, even if they are not being loaded it works fine. I cannot guarantee that there are plugins available for this package as they are plugins to be defined optionally, so the program should work without any plugins.
I could probably fix this by defining a dummy plugin in the the_exec package, but I'm wondering if there is a better cleaner way or how to fix this properly.
Originally posted by dornhege on ROS Answers with karma: 31395 on 2011-11-15
