I am working on the ETH ROS online course exercise 3 but I cannot get the transform part working. My tfbuffer cannot get filled and my lookuptransform ends up with "target frame does not exist".
I have verified that the frames do exist and my ros rate is correct. So I think the problem is in the C++ class programming .But I don't know how to deal with it
I have three main files in the system:
  1. husky_highlevel_controller_node.cpp
  2. husky_highlevel_controller.cpp
  3. husky_highlevel_controller.hpp
Bascially the node file has the main function and declares a husky_controller object. Then all the actual code are in the constructor of the object. This is the node.cpp file:
int main(int argc, char **argv) { ros::init(argc, argv, "husky_highlevel_controller");
// create a private namespace nodeHandle ros::NodeHandle nodeHandle;
ros::Rate rate(1.0); husky_highlevel_controller::HuskyHighlevelController huskyHighlevelController(nodeHandle);
ros::spin(); return 0; }
Then, I put tf2_ros::Buffer tfBuffer; tf2_ros::TransformListener tfListener(tf2_ros::Buffer tfBuffer);
in the private section of the class in the .hpp file.
Lastly, in the husky_highlevel_controller.cpp namespace constructor file, I put
tf2_ros::TransformListener tfListener(tfBuffer);
if (tfBuffer.canTransform("odom","base_laser",ros::Time(0))){
ROS_INFO("Cantransform"); } else { ROS_INFO("Cannot transform"); }
I just keep getting "Cannot transform") no matter what I do. It seems that tfBuffer is not even filled.
Please help ! Thank you.
Originally posted by Jeff on ROS Answers with karma: 16 on 2017-06-10
It's funny. I figured it out.
Basically, you need to put your listener declaration inside the callback function. Otherwise it wont work
Originally posted by Jeff with karma: 16 on 2017-06-10
