I have another problem that need your help,
I built a data.bag using rosbag as tutorial with transform
Heading
#include <ros/ros.h> #include <tf/transform_broadcaster.h>
int main(int argc, char** argv){ ros::init(argc, argv, "urca_hokuyo_tf"); ros::NodeHandle n;
ros::Rate r(100);
tf::TransformBroadcaster broadcaster;
while(n.ok()){ broadcaster.sendTransform( tf::StampedTransform( tf::Transform(tf::Quaternion(0, 0, 0, 1), tf::Vector3(0.1, 0.0, 0.2)), ros::Time::now(),"base_link", "hokuyo_scan")); r.sleep(); } }
, but when i use rosrun gmapping slam.. and rosbag play and rosrun map_sever map_saver. I do not create a map.
Please, show me how can i fix it
Originally posted by ThiemPHAM on ROS Answers with karma: 46 on 2016-12-07
First, make sure whether the bag file you have recorded has data or it is empty. This can be done by
rosbag play --clock data.bag
Then echo the topic to check whether the bag file is publishing data.
Originally posted by Gokul with karma: 243 on 2016-12-07
