Hi guys, I've used QT to create a package with GUI and a ROS node (subscriber), and every thing works as I expected. Now I need to add a new publisher node to my QT. Please help me to do this if you have any idea.
Thanks
my whole code is here Main.cpp
#include "ros/ros.h"
#include "std_msgs/String.h" #include "mainwindow.h" #include #include <boost/thread.hpp> #include #include <string.h> #include #include #include #include #include #include "newwindow.h" #include #include #include "gui_sub/Position.h"
using namespace std; MainWindow* mainWin;
void infoCallback(const std_msgs::String::ConstPtr& msg) { // ROS_INFO("The New module is: [%s]", msg->data.c_str()); std::string str = msg->data; //The Name of Raspberry Pi std::string str_name = str.substr (14,19); // List of Servo motors std::string str_servo_1 = str.substr (55,23); std::string str_servo_2 = str.substr (82,23); std::string str_servo_3 = str.substr (109,23); std::string str_servo_4 = str.substr (136,23); // List of Brushless motors std::string str_brushless_1 = str.substr (163,25); std::string str_brushless_2 = str.substr (192,25); std::string str_brushless_3 = str.substr (221,25); std::string str_brushless_4 = str.substr (250,25);
//Converting the STD Strings to QStrings
QString qstr = QString::fromStdString(str);
QString qstr_name = QString::fromStdString(str_name);
QString qstr_servo_1 = QString::fromStdString(str_servo_1);
QString qstr_servo_2 = QString::fromStdString(str_servo_2);
QString qstr_servo_3 = QString::fromStdString(str_servo_3);
QString qstr_servo_4 = QString::fromStdString(str_servo_4);
QString qstr_brushless_1 = QString::fromStdString(str_brushless_1);
QString qstr_brushless_2 = QString::fromStdString(str_brushless_2);
QString qstr_brushless_3 = QString::fromStdString(str_brushless_3);
QString qstr_brushless_4 = QString::fromStdString(str_brushless_4);
// Using the new strings to create our lists via signal and slot methods
mainWin->updatemethod_info(qstr);
mainWin->updatemethod_name(qstr_name);
mainWin->updatemethod_servo_1(qstr_servo_1);
mainWin->updatemethod_servo_2(qstr_servo_2);
mainWin->updatemethod_servo_3(qstr_servo_3);
mainWin->updatemethod_servo_4(qstr_servo_4);
mainWin->updatemethod_brush_1(qstr_brushless_1);
mainWin->updatemethod_brush_2(qstr_brushless_2);
mainWin->updatemethod_brush_3(qstr_brushless_3);
mainWin->updatemethod_brush_4(qstr_brushless_4);
} void callbackmethods() { ros::NodeHandle n; ros::Subscriber sub = n.subscribe("/info", 1000, infoCallback); ros::Rate rate(30); while (ros::ok()){ ros::spinOnce(); rate.sleep(); } }
int main(int argc, char **argv) { ros::init(argc, argv, "gui_sub");
QApplication app(argc, argv);
app.setOrganizationName("Trolltech");
app.setApplicationName("Application");
mainWin = new MainWindow();
mainWin->show();
//boost::thread thread_spin( boost::bind( ros::spin )); boost::thread thread_spin( boost::bind( callbackmethods ));
ros::init(argc, argv, "servoinput"); ros::NodeHandle nt; ros::Publisher position_pub;
position_pub=nt.advertise<gui_sub::Position>("position", 1000);
std::string di; gui_sub::Position msg; std::cout << "I am here "; std::cin>>di; msg.position = atof(di.c_str()); position_pub.publish(msg);
return app.exec(); }
Originally posted by Saeid on ROS Answers with karma: 3 on 2015-06-29
Create another publisher (class) inside the node like in the C++ tutorial for creating nodes? Should be something like this:
ros::Publisher pub; //When in class this is the member in class definition
pub = nh.advertise<pkg::TopicType>("awesome_topic", 1000 /*Queue*/); //This goes to Constructor
//Maybe your main loop
ros::Rate rate(10);
while(ros:ok())
  pkg::TopicType msg;
  /*add data to your msg here*/
  msg.field="some data";
  pub.publish(msg); //Publish it
  ros::spinOnce();
  rate.sleep(); //limit loop rate
See here: http://wiki.ros.org/ROS/Tutorials/WritingPublisherSubscriber%28c%2B%2B%29
Originally posted by cyborg-x1 with karma: 1376 on 2015-06-29
Comment by Saeid on 2015-06-30:
Many thanks for your interest to answer my question. I tried to do what you mentioned by adding this lines to my Main.cpp : (NEXT COOMENT)
ros::Publisher position_pub; ros::NodeHandle nt;
position_pub=nt.advertise<beginner_tutorials::Position>("position", 1);
std::string di="1.5"; beginner_tutorials::Position msg; msg.position = atof(di.c_str()); position_pub.publish(msg);
But unfortunately it's not publishing .
Comment by cyborg-x1 on 2015-06-30:
Could you please paste the whole code? Maybe edit your answer and add it.
Probably in qt you will have your main "ros" loop in a second thread.
Ahh now I see you problem.
 position_pub=nt.advertise<gui_sub::position>("position", 1000);
must go into a function you call. I did not think of the main function of the Qt project, just put it somewhere shortly after where you set the values of the message.
normally when using Qt you put the while(ros::ok()) loop inside a function of a seperate thread. You are executing ros::spin() as thread, it does take care of the incomming messages and calls the callback functions. publish(msg) should be able to be called anywhere.
Thank you man, It works now, thanks a lot for your help man
You're welcome ;-)
