Hi Ringo,
I have a possible solution for you below but first here is a summary of what I tried. I am using Ubuntu 10.04 with the festival debian packages obtained using the Synaptics package manager.
First I tried your scenario with the latest Diamondback debian packages and confirmed that I also get the slow low voice. (I reported this a while back as a bug.)
Next I tried it with the latest Electric beta debian packages and in this case, launching the sound_play node fails with the following error:
process[soundplay_node-2]: started with pid [5505]
File "/opt/ros/electric/stacks/audio_common/sound_play/scripts/soundplay_node.py", line 49, in <module>
from diagnostic_msgs.msg import DiagnosticStatus, KeyValue, DiagnosticArray
ImportError: No module named diagnostic_msgs.msg
[soundplay_node-2] process has died [pid 5505, exit code 1].
log files: /home/patrick/.ros/log/d13001dc-c1ef-11e0-9414-0022683b2a0b/soundplay_node-2*.log
The fix I have found that works with both Diamondback and Electric is to overlay the latest audio_common stack as follows:
$ cd /home/ringo/ros (or whatever your personal ROS directory is)
$ sudo apt-get install mercurial
$ hg clone `roslocate uri audio_common`
$ rosmake --rosdep-install audio_common
Then run:
$ rospack profile
in each of your terminal windows and try this test:
In the first terminal:
$ roslaunch sound_play soundplay_node.launch
and in the second terminal:
$ rosrun sound_play say.py "How do I sound now?"
IMPORTANT: In your Python program, you need to add a second argument to the SoundClient say() command. So this:
self.soundhandle = SoundClient()
rospy.sleep(1)
self.soundhandle.say('Take me to your leader.')
becomes this:
rospy.sleep(1)
self.soundhandle.say('Take me to your leader.', '')
The second argument is for specifying the voice, but I have only tried setting it to the null string.
Hope that works for you!
--patrick
Originally posted by Pi Robot with karma: 4046 on 2011-08-08
Comment by Per Lenander on 2011-11-24:
Running Ubuntu 11.04 with the latest audio_common stack, I had the same problem as described above. I applied the last part of the solution (Set the voice to the null string, or "" in C++) and this works for me.
