Hi! whenever i try to run ros commands such as roscore or rosmake, it keeps popping up >>
File "/opt/ros/electric/ros/bin/roscore", line 34, in from ros import roslaunch File "/opt/ros/electric/ros/core/roslib/src/ros/init.py", line 55 except roslib.packages.InvalidROSPkgException as e: ^ SyntaxError: invalid syntax
I would b glad if any of you can solve this problem.my default python version is 2.6.6. thanks in advance!
Originally posted by vasp on ROS Answers with karma: 1 on 2011-10-08
Comment by kwc on 2011-10-10:
The syntax error would tend to indicate an older, not newer Python.
Comment by roehling on 2011-10-10:
I just installed Python3.2 (Ubuntu 11.04), ran some ROS stuff with it, and I got an AttributeError exception. So while I agree with Lorenzo that this looks like some sort of Python version conflict, I am unable to reproduce the same error.
Comment by Lorenzo Riano on 2011-10-10:
I think it's due to a Python 2.6 -3 conflict. Röhling maybe you should post your comment as an answer.
Are you sure that your ROS binaries actually use Python 2.6? The Syntax Error exception indicates otherwise. Do you have Python 3.x installed?
Comment by vasp on 2011-10-09:
i'm using Ubunthu 10.10 and ros electric package. not only ros core..all the roscommands like rosdep, roswtf also giving me the same error.it was working fine last time. i didnt even update the versions. but since it's not working i tried updating the ubunthu, python version and ros package. but i still hav the same problem.
Comment by Mac on 2011-10-09:
Tell us more; which sort of system are you on?
