I am trying to learn something by using the ALICE code to let it able to speak. I follow the instruction given by the books "Learning robotic using python" in chapter 8. But I have problem on making it speak and also speech recognition.
To make it speak, I am using sound_play package in ROS. Due to the problem, I tested it with:
> roslaunch sound_play soundplay_node.launch
Then it come out with error as follow:
.. logging to /home/user/.ros/log/bd387f44-f6c5-11e7-ac01-b0359f36d413/roslaunch-user-HP-Laptop-4644.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://user-HP-Laptop:36451/
SUMMARY
PARAMETERS * /rosdistro: kinetic * /rosversion: 1.12.7
NODES / soundplay_node (sound_play/soundplay_node.py)
core service [/rosout] found process[soundplay_node-1]: started with pid [4662] Traceback (most recent call last): File "/home/user/catkin_ws/src/audio_common/sound_play/scripts/soundplay_node.py", line 48, in from sound_play.msg import SoundRequest, SoundRequestAction, SoundRequestResult, SoundRequestFeedback ImportError: No module named sound_play.msg [soundplay_node-1] process has died [pid 4662, exit code 1, cmd /home/user/catkin_ws/src/audio_common/sound_play/scripts/soundplay_node.py __name:=soundplay_node __log:=/home/user/.ros/log/bd387f44-f6c5-11e7-ac01-b0359f36d413/soundplay_node-1.log]. log file: /home/user/.ros/log/bd387f44-f6c5-11e7-ac01-b0359f36d413/soundplay_node-1*.log all processes on machine have died, roslaunch will exit shutting down processing monitor... ... shutting down processing monitor complete done
I'm not sure why is this happen... Can anyone helps please? TT
Originally posted by Mich K on ROS Answers with karma: 1 on 2018-01-11
You have the package cloned into your workspace. The error message is saying, that the message file for python cannot be found. This file is auto-generated once you compile your Workspace.
I guess you just have to call a catkin_make (or catkin build, whatever build command you use), and if this compiles successfully, you are good to go...
Originally posted by mgruhler with karma: 12390 on 2018-01-11
