Hello everyone,
I was wondering if anyone had a working version of a launch file for a navigation stack, using a SICK LMS rangefinder for the sensor and their odometer and transform nodes, that they could let me look at to get a better understanding of how the navigation stack fits together. I've been doing the tutorial RobotSetup for the navigation stack, and after completing the transform configuration portion and using
node pkg="sicktoolbox_wrapper" type="sicklms" name="sicklms" output="screen"
with its corresponding parameters for the sick lms rangefinder I seem to be hung up. I don't quite understand where to put the odometry code, nor how to reference the transform configurations or odometry file for the node requirements during the launch file. Also, I'm using a Pioneer AT3 so I didn't know if there was an odometry package for this robot or not? Or if it is possible to use ROSARIA or p2os to build a map of a building with the robot?
Any help would be greatly appreciated! Thanks, Jason
Originally posted by Jason on ROS Answers with karma: 11 on 2011-03-28
I'll answer in two parts:
  1. Sample Navigation Using SICK
    Take a look at cwru-ros-pkg for a complete navigation stack setup using the SICK laser. The launch files you should look at are the cwru_bringup_no_tele.launch and cwru_nav/start_nav.launch (though start_nav.launch assumes that someone has already brought up a map_server, like in cwru_nav/start_amcl_2ndfloor.launch). You should be able to trace the included launch files, configs and such to get an example working navigation stack for our differential drive robots.
  2. Odometry for the Pioneer
    Yes, you can use something like p2os to get odometry from a Pioneer. See the Getting Started with p2os tutorial for how to setup your Pioneer. As long as p2os outputs reasonable odometry estimates and the required transforms, you should be able to use your SICK to make a map with gmapping.
Originally posted by Eric Perko with karma: 8406 on 2011-03-28
Comment by Jason on 2011-04-26:
Sorry it's been awhile since I asked this I've been stuck doing other work. If you were running the tutorial http://www.ros.org/wiki/navigation/Tutorials/RobotSetup and you were to run the line roscreate-pkg my_robot_name_2dnav move_base my_tf_configuration_dep my_odom_configuration_dep my_sensor_configuration_dep to create your package, what would your dependencies be for your setup? I created the transform function and it seems to work fine, but I'm unsure as to where to put the sample Odometry code and how to reference the transform code. I'm trying to do roscreate-pkg robot_2dnav move_base robot_setup_tf sicktoolbox_wrapper and then I'm unsure what to put for the odometer dependency. Also the robot_setup_tf doesnt take so is this not how to reference the tf I created earlier in that same tutorial? Any help would be greatly appreciated. Thanks
