Could NOT find gazebo (missing: gazebo_DIR) -- Could not find the required component 'gazebo'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found. CMake Error at /opt/ros/noetic/share/catkin/cmake/catkinConfig.cmake:83 (find_package): Could not find a package configuration file provided by "gazebo" with any of the following names:
gazeboConfig.cmake
gazebo-config.cmake
Add the installation prefix of "gazebo" to CMAKE_PREFIX_PATH or set "gazebo_DIR" to a directory containing one of the above files. If "gazebo" provides a separate development package or SDK, be sure it has been installed.
    $\begingroup$ Do you have ros-noetic-gazebo-ros installed? $\endgroup$
    – Yato
    Commented Jun 6 at 15:03
