I'm trying to set up MoveitGroupInterface
for robot manipulator.
Long story short, I'm not able to fetch current robot state.
I manage to initialize MoveGroupInterface
and read robot description (so it seems), however, when calling following code snippet:
void m2Iface::getArmState()
currPose = m_moveGroupPtr->getCurrentPose(EE_LINK_NAME);
// current_state_monitor
m_robotStatePtr = m_moveGroupPtr->getCurrentState();
As output of the following command I get:
Didn't receive robot state (joint angles) with recent timestamp within 1.000000 seconds. Requested time 3533.035000, but latest received state has time 0.000000.
I want to initialize moveit2_iface
node with the MultiThreadExecutor
as follows:
// Create node
rclcpp::Node::SharedPtr node = std::make_shared<m2Iface>();
// Add multithreaded executor --> Check MoveIt states for multithreaded executor and relation with time
rclcpp::executors::MultiThreadedExecutor executor;
executor.add_node(node);
executor.spin();
My m2Iface
constructor is:
node_ = std::make_shared<rclcpp::Node>(this->get_name(),
rclcpp::NodeOptions().automatically_declare_parameters_from_overrides(true));
// TODO: Load config path from param
config = init_config("/root/ws_moveit2/src/arm_api2/config/franka_sim.yaml");
RCLCPP_INFO_STREAM(this->get_logger(), "Loaded config!");
// TODO: Add as reconfigurable param
std::chrono::duration<double> SYSTEM_DT(0.005);
timer_ = this->create_wall_timer(SYSTEM_DT, std::bind(&m2Iface::run, this));
PLANNING_GROUP = config["robot"]["arm_name"].as<std::string>();
EE_LINK_NAME = config["robot"]["ee_link_name"].as<std::string>();
ROBOT_DESC = config["robot"]["robot_desc"].as<std::string>();
PLANNING_SCENE = config["robot"]["planning_scene"].as<std::string>();
MOVE_GROUP_NS = config["robot"]["move_group_ns"].as<std::string>();
ns_ = this->get_namespace();
init_publishers();
init_subscribers();
init_moveit();
RCLCPP_INFO_STREAM(this->get_logger(), "Initialized node!");
My moveit init methods are:
void m2Iface::init_moveit()
RCLCPP_INFO_STREAM(this->get_logger(), "robot_description: " << ROBOT_DESC);
RCLCPP_INFO_STREAM(this->get_logger(), "planning_group: " << PLANNING_GROUP);
RCLCPP_INFO_STREAM(this->get_logger(), "move_group_ns: " << MOVE_GROUP_NS);
// MoveIt related things!
moveGroupInit = setMoveGroup(node_, PLANNING_GROUP, MOVE_GROUP_NS);
pSceneMonitorInit = setPlanningSceneMonitor(node_, ROBOT_DESC);
robotModelInit = setRobotModel(node_);
and
bool m2Iface::setMoveGroup(rclcpp::Node::SharedPtr nodePtr, std::string groupName, std::string moveNs)
// check if moveNs is empty
if (moveNs == "null") moveNs="";
// set mGroupIface
m_moveGroupPtr = new moveit::planning_interface::MoveGroupInterface(nodePtr,
moveit::planning_interface::MoveGroupInterface::Options(
groupName,
moveit::planning_interface::MoveGroupInterface::ROBOT_DESCRIPTION,
moveNs));
RCLCPP_INFO_STREAM(this->get_logger(), "Move group interface set up!");
return true;
ROS param use_sim_time
is set to True
for all running ROS nodes.
I'm thinking it could be related to following:
But I'm not really able to figure it out.
env
ROS 2 Humble
Moveit2 build from source on humble branch
MultiThreadExecutor
output is:Didn't receive robot state (joint angles) with recent timestamp within 1.000000 seconds. Requested time 539.621000, but latest received state has time 0.000000.
When usingSingleThreadExecutor
, output is:time 555.269000, but latest received state has time 552.172000.
