I am using Ubuntu 20.04 LTS desktop and ros Noetic
i have installed this library robot_state_publisher for integrate the imu and Lidar,
when I clone the repo from GitHub in my workspace src folder
then I came back to workspace and I did catkin_make
I want to use tf to get updated in real-time using this package
it gave me an Error : the Error is following:
-- ~~ - rviz_imu_plugin
CMake Error at /opt/ros/noetic/share/catkin/cmake/catkin_workspace.cmake:100 (message):
This workspace contains non-catkin packages in it, and catkin cannot build
a non-homogeneous workspace without isolation. Try the
'catkin_make_isolated' command instead.
CMakeLists.txt:69 (catkin_workspace)
See also "/home/aiot/ros_slam/build/CMakeFiles/CMakeOutput.log".
See also "/home/aiot/ros_slam/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed```
