Hi, I am using ROS jade and I needed velodyne package for my module. So I used the tutorial describe in http://answers.ros.org/question/226594/how-do-i-build-ros-vlp16-velodyne-driver-for-indigo-using-catkin/
and built velodyne package for ROS Jade. After that when I do catkin_make
I get following errors:
-- Using these message generators: gencpp;geneus;genlisp;genpy CMake Error at /opt/ros/jade/share/catkin/cmake/catkinConfig.cmake:75 (find_package): Could not find a package configuration file provided by "velodyne_pointcloud" with any of the following names:
velodyne_pointcloudConfig.cmake
velodyne_pointcloud-config.cmake
Add the installation prefix of "velodyne_pointcloud" to CMAKE_PREFIX_PATH or set "velodyne_pointcloud_DIR" to a directory containing one of the above files. If "velodyne_pointcloud" provides a separate development package or SDK, be sure it has been installed. Call Stack (most recent call first): azcar_sim/CMakeLists.txt:7 (find_package)
-- Configuring incomplete, errors occurred! See also "/home/jane/ros15/trunk/gazebo_workspace/build/CMakeFiles/CMakeOutput.log". See also "/home/jane/ros15/trunk/gazebo_workspace/build/CMakeFiles/CMakeError.log". make: *** [cmake_check_build_system] Error 1
I don't know how to fix that. Can somebody help me?
Thanks. Rahul
Originally posted by cybodroid on ROS Answers with karma: 234 on 2016-02-26
Okay, so I realized that my module and velodyne package that I had downloaded from git were in different catkin workspace. I resolved it by downloading and making velodyne package in same catkin workspace.
Thanks.
Originally posted by cybodroid with karma: 234 on 2016-02-26
