I'm building a 2-wheel balancing robot from old parts. DC motors from an old printer, wheels from a BBQ, bodywork from an old optical drive etc.
The brain of the robot is a Raspberry Pi 3. I'm using an L298N motor driver to control 2x 12-35v DC motors. Balance and movement will be 'sensed' using a 10DOF L3GD20 LSM303D Gyro, Accelerometer & Compass board. I'm currently using an Arduino with PWM for multi speed and direction of each motor. A PID loop will keep the robot balanced.
It looks like this: Raspberry Pi > Arduino > L298N > Motors
So far everything is good (don't worry I'm not going to ask "Where do I start??" :D)
My question is this: should I continue to control the sensors and motors' driver using the Arduino, having the Pi issue higher level commands to the Arduino, OR should I just let the Pi do all the leg work?
I'm trying to keep power consumption to a minimum but I want to keep the processing overhead of the balancing and movement away from the Pi. Additionally, I've read that an Arduino is better at this sort of work due to the fact that it has a built in clock, where a Pi doesn't. I assume the PID loop will be slowed if the device (the Pi) is working on other processing tasks like navigation and face recognition etc.
Are my assumptions correct and which direction would guys steer towards?
Your knowledge and wise words would be very much appreciated!!
