I am using the L298N motor driver to drive two HAD1 linear actuators (12V each and a no-load drive current of ~950mA each)
Linear Actuator: http://www.alibaba.com/showroom/mini-linear-actuator-had1.html
Motor Driver: is a L298N dual-h-bridge motor-driver controller board-module for arduino robot
I am also using a current sensor per motor to get feedback of what the motor is doing (only sensors I have available, but I can detect of the motors are moving or stopped). I am using two ACS714 current sensors. The supply voltage for each is 4.5V to 5.5V and Supply Current is 10mA to 13ma:
Current Sensor: is an ACS714 current sensor.
And Here is the circuit diagram that I made for my actual setup (an Arduino UNO, two current sensors, to linear actuators, and one motor drive):
Circuit Diagram:
Will this setup work? Will I have enough current/power coming out of the 5V of the arduino to power both the L298N logic and the two ACS714 sensors?
